Will the turbo work?
Old 07-22-2008, 10:12 PM
BBA
BBA's Avatar
Ok I may be buying a turbo off a 12 valve if it will fit up on my 24 valve. Help would be greatly appreciated! Thanks!
Kevin
Old 07-23-2008, 09:04 PM
HOHN's Avatar
It will fit. If it's an H1C or WH1C, this would be a step backwards in performance...
Old 07-23-2008, 09:13 PM
BBA
BBA's Avatar
Haha well thanks. I actually wasnt looking at a stock turbo but a II silver 62 found a great deal on one but it was on a 96 12v and I wasnt sure but I had gotten the answer and ordered it today!
Thanks again.
Old 07-25-2008, 10:51 AM
The Guru
Mike Holmen's Avatar
When you loss your VP, buy a SO pump instead of the HO pump. you'll pick some top end power that your new sps62 will provide you. Whats the size of turbine housing?
Old 07-26-2008, 02:39 PM
jerrethomas's Avatar
I didn't think you could swap a HO for a So pump. I was always under the impression that something in the computer was different.
Old 07-26-2008, 04:14 PM
BBA
BBA's Avatar
Actually I have SO pump (i think its a SO) sittin in the garage I have thought about puttin back in there(long story on why its not in there) but I just dont know if Im up to a injection pump change.
And its a 62/74/14. How do yall think it will be with my setup? Maybe over 500hp?
Old 07-26-2008, 06:31 PM
dieselfan's Avatar
you ll def, have enough air for 500+. my 62/71/13ss was suppose to come in today but fedex didnt even try to deliver and their office isnt open till tuesday.
i wonder what your spool up will be like with that 74/14.
i think you ll over 500.
Old 07-26-2008, 09:07 PM
BBA
BBA's Avatar
Yea i know I will have enought air but what about fuel?
And spool up cant be any worse than these crappy twins I got!
Old 07-27-2008, 07:02 AM
HOHN's Avatar
Don't bet on it. You might be wishing for the "crappy twins" again.
The large turbine on the Silver turbos is great for nitrous and pushing a compressor far off its map. But if you're within the design considerations of the compressor, the larger turbine isn't of that much benefit, imo. It will flow more freely at high boost levels, but you give up a good bit of spoolup to get that last 5% or so..
(see sig)
Old 07-27-2008, 08:05 AM
BBA
BBA's Avatar
(see sig)
Well when I say crappy twins I mean the take forever to spool for twins (2300-2400 rpms) thats probably the best they have started spooling.
Old 07-27-2008, 08:18 AM
HOHN's Avatar
I'd suggest trying to fix what's wrong with your twins setup. Sometimes a housing swap and/or wastegate tuning can do wonders.
Old 07-27-2008, 10:20 AM
BBA
BBA's Avatar
Do you not think that this turbo will spool faster than 2300rpm's?
Old 07-27-2008, 12:36 PM
HOHN's Avatar
I'm not trying to quantify the performance of the big single. I'm saying that the twins should do better than any single--- they need some tweaking to perform right.
If the twins aren't spooling until 2300rpm, then something isn't right. When you fix whatever is wrong, you'll have a setup that is much better overall than a large single.
JMO
Old 07-27-2008, 01:26 PM
BBA
BBA's Avatar
JMO
I agree completly! Im just getting really tired of trying to figure out what the problem is with no availe. i guess If I dont like this turbo I can always sell it after saving up for a good set of twins that arent a throw together kit.
Old 07-27-2008, 01:30 PM
dieselfan's Avatar
tell us about your twins.
Quick Reply: Will the turbo work?
