Turbo timer fixed now no psi?
Old 07-17-2009, 12:01 AM
Jeff5886's Avatar
My turbo timer wasn't working. I replaced the edge juice with a new one (from edge). It works again but now what I turn the key off the engine stays running but the airdog turns off, which in turn gives me a 1psi fuel reading. ***?
2000 Dodge 2500 Sport Cummins 24 Valve, 4x4, Auto, Quad Cab, Short Bed With BHAF, Airdog 100, Edge Juice with Attitude, 5" TB Exhaust
Old 07-17-2009, 04:32 AM
Fishin2Deep4U's Avatar
I'll bet you are tapped into a keyed source for power to the relay trigger, right?
If so, you need to be tapped into the ECM harness that went to the original lift pump.
Old 07-17-2009, 07:41 AM
Jeff5886's Avatar
Are you refering to the airdog or the edge (turbo timer)
Old 07-18-2009, 01:44 AM
AirDog.
Dave
Old 07-18-2009, 07:18 AM
Jeff5886's Avatar
where on the ecm harness do i tap at?
Old 07-20-2009, 08:26 PM
Jeff5886's Avatar
After looking at how the airdog was connected i found that the power it get comes from the battery. The other connection plugged right into the ECM via the old fuel pumps electrical harness. So in theroy it should be controlled by the ecm the same way that the original fuel pump was. Also just to be sure I turned the engine offand left the key in accessory mode ans the airdog still doesn't stay running, so that rules out the idea that it is tapped into a keyed fuse. So why would it stop running when I turn the key off and the engine stays running?
Old 07-21-2009, 03:16 PM
Mopar_Man's Avatar
Isnt it the #9 fuse it should be getting its power from to keep it running after the key is turned off?
Old 07-21-2009, 03:20 PM
Jeff5886's Avatar
I have the edge turbo timer wire connected to that fuse...
Old 07-21-2009, 03:21 PM
Mopar_Man's Avatar
What i ment was i think the pump needs to be hooked to that also to keep it running wile the key is off.
Old 07-21-2009, 03:23 PM
Jeff5886's Avatar
The you mean the hot wire for the pump? The only connections to the pump besides ground are hot to the battery and the plugin to the ecm.....are you saying i should tap the hot into the fuse 9
Old 07-21-2009, 03:24 PM
Mopar_Man's Avatar
I think something needs to be conected ther to keep the pump on, I could be wrong but I think thats how my FASS is hooked up.
Old 07-21-2009, 03:26 PM
Jeff5886's Avatar
Ill give it a shot tonight, anyone else wana chime in...
8Lug_hotrod
04-18-2021 08:07 AM
06RAMCTD
11-06-2009 11:35 AM
CTDPower11
01-23-2007 09:29 AM
TripleBquad
13
11-20-2006 02:59 PM
jwtuc
03-22-2004 08:35 PM
Quick Reply: Turbo timer fixed now no psi?
