65dragnet
08-22-2007, 09:03 PM
Would it be a benefit or an upgrade , so to speak , to go from a WH1C turbo (on my 95 CTD ) to a HX35 ? Thanks!!
JD730
08-23-2007, 07:32 AM
There is no real advantage between a WH1C and a HX35. The only real difference is the method the compressor housing is attached, the WH1C has a v-band clamp that holds the compressor housing to the back plate and the back plate bolts to the center section. The HX35 uses a snap ring to hold the compressor housing to the back plate and the back plate is cast as part of the center section.
65dragnet
08-23-2007, 05:27 PM
Thanks JD730! That's what I was looking for!
