turbo
Old 05-27-2006, 05:20 PM
kinser5mfan's Avatar
turbo
fairly new to this so be gentle............
after driving my truck a few blocks to take a friend home, i parked in the driveway and walked to the back of the truck where i could hear the turbo still moving air!! i was scratching my head when my son came up and said he loves it when my truck makes that noise. i asked who often he has heard it and he said all the time
after letting the truck sit a while i started it idled for a few minutes and had him shut it off sure enough there it was again..
so finaly my question..... is the turbi really spinning up just setting there or what am i hearing kirby
Old 05-27-2006, 10:50 PM
CTD01's Avatar
Turbo
You will hear the turbo for a few seconds after you shut off the truck. I really noticed it after I put my intake and exhaust on. I can also faintly hear it when my truck is idling.
Paul
Old 05-28-2006, 07:48 AM
RowJ's Avatar
Turbos spin over 100,000 rpm under a load. Not sure of rpm at idle, but it does take a while form them to stop spinning after shut down.
That's why cooling down the Pyro to a min of <300* before turning engine off, is important. Without the cool down...heat soak can be serious. Have seen a spinning turbo sitting in a static oil bath (truck turned off) take a pyro reading up to 500*...well past the oxidizing temp of even good oils!
RJ
Old 05-31-2006, 06:37 AM
thanks just needed to check this out
Old 06-04-2006, 01:24 PM
sledcrusher02's Avatar
get a balanced ball bearing turbo and watch how long that sucker spins aftr shutdown the motor will be cooled down when its stoped! a little stretch but close.
Ada381
02-10-2008 07:58 AM
j
01-09-2004 08:19 AM
Haulin_in_Dixie
07-21-2003 11:14 AM
redram
12-10-2002 09:54 AM
Quick Reply: turbo
