turbo size advice
Old 02-12-2010, 09:39 AM
Diesel Demon's Avatar
turbo size advice
I popped the head gasket on my truck. I am installing arp head studs on the truck now and and a good gasket. I am also going to put on a bigger turbo and down pipe on the truck. I would like to know what size turbo I should install on it. This truck is my daily driver. i do not tow that often with the truck. I would like some input as to what would be a good all around turbo to install on it. You can tell by my sig what I have done to the truck allready. Any advise would be a great help. Thank you for your time Garry
Old 02-12-2010, 10:18 AM
sheriffav8r's Avatar
With those mods, you just need to figure out how much power you want. From my limited knowledge I'd say single turbo setups go from an HX-35/40 Hybrid, S300 or Super B, Turbonetics 15181, PhatShaft 62, HTT 64/65/13ss, on up. Most of the above are good for 300-500HP. The Hybrid is the cheapest and from what I can tell, you'll want a bigger one pretty soon after that. The rest can be used in a twins setup so you don't have to start all over again when you upgrade. Just depends on how much money you want to shovel out....
Old 02-12-2010, 11:52 AM
pgdsm's Avatar
I'd say a 62/65/14 or if you are thinkng twins in the future and want something easier on the budget now pick up a he351 it's a 60/60/9 and bore out the wastegate to jst over an inch. Guys have ran those on a vp with 150's and seen upwards of 460hp while dp is still in check ( barely over a 1:1 ratio)
Old 02-12-2010, 12:17 PM
I am not concerned about what the cost is. I want the truck reliable and hold together. I am not going to mod it anymore after these upgrades the truck is to a point that I am happy with it. It has enough power for what i use it for. Thanks for the input so far keep them coming every little bit of info helps. Thanks Garry
Old 02-12-2010, 03:10 PM
Brendan's Avatar
Probably something like a BD Super B would be very nice, very fast spooling and good to 400-450 hp.
Old 02-12-2010, 05:04 PM
DIESELWRKS's Avatar
I would lean towards a HTT turbo talk to these guys great people Rip knows his products and wont steer you wrong. they are just good people. not bashing any other turbo I have had zero probs with all of the HTT turbo's I have owned.
www.sourceautomotive.biz
Old 02-12-2010, 05:57 PM
Big Deezul's Avatar
I just got the HTT 64/65/13ss and I have nothing but good things to say about it. EGT's are much lower then my HX40 and I am running it set to make less boost right now.
head studs on the way
Old 02-13-2010, 09:38 AM
I found a new turbo for 1100. it is a hollset turbo one size bigger than i have on the truck what do you guys think about that turbo and a 4 in down pipe. tell me what you think
Old 02-13-2010, 09:44 AM
What pressure are you running on that? It seems that that particular turbo is a great way to go....
As far as a turbo for you, Diesel Demon, I think you could get a HX-35/40 hybrid and that would be the best way to go. You can get that for about $1200. Fast spooling like the HY but with a stronger shaft than the HX-40...
Old 02-13-2010, 09:55 AM
jcw74801's Avatar
I found a great price on a Super B with downpipe and shipping. I haven't bought anything from them:
http://tinyurl.com/ycq2qly
Old 02-14-2010, 11:36 PM
The Guru
Mike Holmen's Avatar
Who makes the 120hp sticks? I suggest a garrett GT3782R, I run that turbo for nearly 100000miles, with that sized sticks. I peak around 46psi of boost and egt's around 1200-1300 deg's. Depending on what sticks your running, you'll need a bigger turbine housing/disk. You tow, how heavy?
Old 02-14-2010, 11:45 PM
DodgenIt's Avatar
Keep an eye on the classifieds on here too. Seem to be alot of tubo,s in there lately.
Havent heard of that site, but 1,150 is a good price for a Super B.
Old 02-15-2010, 09:44 PM
The Guru
You can get the S362 without a wastegate for less than $1000cdn. The trouble is that your paying one to two middle guys for a borg warner turbo. You can save money if you buy directly from borg warner. I paid around $900 cdn for a S366/0.91 T-4 turbo. I would run the S362/71 turbo if you do any towing. What's you tranny stall at? If you have a higher stall converter, you could go with a bigger turbo. I run a 1800rpm stall in my truck, it helps the spool-ups quite abit.
Old 02-16-2010, 08:18 AM
When you guys talk about 64/65/13 turbo how does that break down to size i need a little help figuring that out. Thanks Garry
Old 02-16-2010, 09:00 AM
The Guru
64/65/14 is 64 compressor inducer size (mm), 65 turbine wheel exducer (mm) and housing size 14 (cm)
65mm turbine disk, will run hotter than a 71mm turbine disk, if you have the fuel
The 64mm compressor inducer will flow around 70lbs/min, the 62mm is around 60lbs/min
Quick Reply: turbo size advice
