PDA
View Full Version : Turbo Question
Rodram2002
11-30-2006, 10:37 PM
My Dad has a 92 CTD and I'm putting twins on my 02 CTD. would my stock hx35 fit on his 92? if no, could you share why?
thanks
Scotty.
rockjeep73
11-30-2006, 10:51 PM
everything would work except the downpipe connection, your hx35 has a cast exhaust elbow that is different than the 1st gens.
Rodram2002
11-30-2006, 10:54 PM
would a custom down pipe make it work?
rockjeep73
11-30-2006, 10:57 PM
ya, or you might just be able to modify the stock downpipe from your 2nd gen, or just modify the 1st gen downpipe and weld an hx35 flange to it.
gman07
11-30-2006, 11:10 PM
You could also just replace the backing plate on the turbine housing with an earlier style for the v-band clamp. Everything else should work fine.
Rodram2002
11-30-2006, 11:43 PM
hhmmm, the turbo on his truck has a 14cm wastegated housing on it. I will have to look and see if it might bolt up. He was looking at doing a new exhaust. might just have a new down pipe made.
bgilbert
11-30-2006, 11:54 PM
Simply remove your 12cm housing and bolt up your hx35 to his 14cm housing on the truck.
TexasHardcore
12-01-2006, 11:32 PM
Just cut the flange off the downpipe...install the turbo...cut the downpipe the needed amount to clear the firewall and then weld the flange back on the downpipe.
gman07
12-02-2006, 12:39 PM
For a 2002 truck, that won't work. They don't use the v-band style clamp like the earlier trucks.
The best plan would be as bgilbert said, just swap the 14cm from his turbo onto the HX35.
