Turbo much loader now
Old 06-14-2007, 05:46 PM
cincydiesel's Avatar
I took out the little white plastic thingy in the factory torque tube. Man does the turbo now. I installed a BHAF thinking that it would make the turbo louder and was disappointed when I couldn't hear much of a difference. So tonight I got the idea to remove the white / clear plactic thingy thats closest to the turbo to see if that would make a difference. Wow what a difference!!!! I can hear at idle. It took a little work to back it out of the tube (about 10 minutes) but it was well worth it.. Well I just thought I would share this with ya'll. I've heard of people talking about taking it out but I've never heard any feed back..
Old 06-14-2007, 06:36 PM
DTR Detective
steelblitzkrieg's Avatar
The curved fins? I only removed the baffles in the straight tube, aren't the curved blades there to help the flow of air more than anything?
Old 06-14-2007, 06:39 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Did you also remove the metal silencer in the front of the turbo?
Old 06-14-2007, 07:19 PM
Yes, the curved fins. I took the air flow into consideration. I removed the fins and drove home without them to see how it would effect my EGTs if anything they went down. I dont see how an obstruction in the air's pathway can help it flow better, but I'm no airodynamic specialist..
Old 06-14-2007, 07:20 PM
Yes.. My silencer ring and baffle have been relocated to my glovebox...
Old 06-14-2007, 09:28 PM
rynemurch's Avatar
Did you cut anything or does all of it just come out?
Old 06-14-2007, 09:31 PM
I took the elbow off (the one connected to the turbo) and with a little work I reversed the plastic fin assembly out of the ruber elbow.
stock03's Avatar
I replaced mine with 5" PVC pipe from Home Depot
Old 06-14-2007, 09:35 PM
rynemurch's Avatar
Just asking cause I want more ! put if I have to take it back to the dealer I want to put it back!
Old 06-14-2007, 10:00 PM
rynemurch's Avatar
I took out the little white plastic thingy in the factory torque tube. ..
Cant get it out! Did you use water and soap?
Old 06-15-2007, 07:24 AM
Nope, I just folded the ruber behind the plastic and worked it out
Old 06-15-2007, 09:24 AM
deezulsmoke's Avatar
Do you get a loud rush of air inside the truck now or just more turbo sing? I know when I had the torque tube i took it off because of all the air rushing thru the tube. Sounded cool, just couldn't handle the noise all the time, but I am looking for more turbo singing !!
Old 06-15-2007, 11:26 AM
I think it sings more at lower RPM's. When I turn my high idle I can hear the turbo. I never heard that before I took it out
Old 06-15-2007, 02:14 PM
BPoulsen's Avatar
I remove the white fins and the silencer ring also - but still have the stock intake with K&N filter - it whistled more with the ring installed than it does now - now it makes more of a whoosh sound... I guess it's time for an AFE intake..
Old 06-15-2007, 02:19 PM
ohyeahfriday's Avatar
do you have to do any cutting to get the baffle out of the tube, we were looking at yanking my brothers, along with his silencer ring, but did not see the easy means rigt away.
Quick Reply: Turbo much loader now
