turbo lag? how?
Old 05-30-2008, 07:39 AM
paroxysym's Avatar
turbo lag? how?
im wondering if i have a boost leak or not. takes me what seems like forever to get it to spool. ive noticed that at 65 mph im below 10 lbs, but before i used to sit at 10 lbs cruising at 65 mph. it dropped a couple lbs. is it the smarty prog i am running? i mean its slow as all heck getting to 10 lbs, but after that it spools pretty quick. i guess im experiencing more lag than anything. just curious what could be causing it? should i double check my gauge connections?
Old 05-30-2008, 07:44 AM
MikeyB's Avatar
I'm thinking since the engine is running more efficiently with the SMARTY it doesn't require as much boost to hold constant speed. But the drawback it a little longer spool up time.
What's your torque management setting? Could bump it up a notch and see if the lag time is shortened.
MikeyB
Old 05-30-2008, 08:27 AM
paroxysym's Avatar
MikeyB
i believe with the jr it comes with a modified tq mgt which i assume would be moderate. you cant bump the tq mgt with the jr i think. also i have the beta download, which was designed to cut back on the amount of smoke you were rollin'.
blueberry
01-11-2006 12:46 AM
crossy
07-14-2005 05:55 AM
ptextreme
03-21-2005 02:02 PM
MY WORLD
26
02-26-2005 06:47 PM
J BODY
06-08-2004 07:16 AM
Quick Reply: turbo lag? how?
