turbo decision
turbo decision
trying to decide between just a regular 62/14 and one of the 71 series 62/14's.
is the low drive presure wheel that big of an advantage? or does it make it lagy at low boost. ?
mods are listed im my sig. clutch will be coming @ same time.
future mods: injectors?, snow stage 2?, and of course some sort of pusher pump.
useage: mostly dayly driving, 70/30 stop&go/hwy. i currently dont tow, but plans are for a boat, and a trilor to tow the jeep. so nothing real heavy by most of you alls standards.
or if some one else has sugestions post up.
I recommend going to a sps or silver 62, work excellent, and great for towing too. I will be able to post how it is in a real race situation after this weekend (im hoping)
Kevin
Kevin
I've had a 71 series 62/14 for a couple of months now and i couldn't be happier with it.Spools pretty good and egts are almost a non-issue. I love a big turbo for tailgaters, can you say smoke screen.
I will probably get flamed for this
but
its the truth
the 62/14 is ok for light to medium towing
even great for romp'n around empty and making high rpm HP
but
is
ABSOLUTELY WORTHLESS FOR HEAVY TOWING
it doesnt have enough spool at or below 2000 rpm
my stocker will tow heavier loads at lower egt's and get better fuel mileage, just cant romp on it too hard
but
its the truth
but
is
but
its the truth
but
is
but
its the truth
but
is
but
its the truth
but
is
but
its the truth
but
is
Thats the ticket there!!!
My SPS62 has no troubles spooling hauling around my 12,000+ lbs 5'ver. No egt problems if i watch what i do and still get good mileage!!!
Jon.
Im talkin 26,000 cgvw
in overdrive at 60 mph, just maintaining speed the exhaust temps sit at 1250 - stock turbo under same condition sits at 950 degrees
theres just not enough drive pressure at low speeds to give enough boost to keep it cool
wound out tight , high rpms , cools great but money out the tail pipe
I am around23 24k gcvw, and love my turbo, I have no problems maintaining speed even on the biggest of grades. Been through the rocky mountains with mine, worked awesome
Kevin
Kevin
i have a gut feeling spooling up shuldnt be a problem...
flat ground, rollin in to it today from about 1k.. by 1200rpm i was making almost 20 lbs on the stock turbo, then the clutch let loose.. oops.
dam i love this beta smarty!
13ALPHA
08-14-2007 09:04 PM
Grey Goose
04-26-2007 12:02 AM
James Lucas
28
09-01-2003 03:25 PM
