turbo back exhaust
turbo back exhaust
All,
I want a turbo back exhaust that eliminates the cat. I see there are a lot of manufacturers out there selling kits, and I want the most bang for my buck. It looks like most of them are 5" mandrel bent tubing. I don't need the stainless exhaust or the fancy tips. I want to spend as little as possible and corrosion isn't an issue where I live.
What systems and how much did you guys spend?
farm boys diesel has the best i wanted quiet so i bought a donaldson m090535 from anderson brothers for $96 and the straight pipe kit fore somewhere around $300 took 2 hours and 30 minutes to get the old off and the new on, no drone nearly quiet as oem
flo pro......
i went with a 5" flo pro turbo-back. i know its more than the typ. muff. delete, etc. it was reasonable, stainless for under $600. it is louder than i had expected, but it does not drone too bad and the sound at full throttle is 'tuff'! if you aren't worried about a little bit of rumble, i would reccomend it. the clamps are dual ring style, very rugged and have had no problems, whatsoever.
krazydher
17
03-06-2010 10:23 PM
newman187
05-02-2008 04:53 PM
Jordan5687
33
02-16-2007 12:37 AM
JoshPeters
04-03-2005 08:13 AM
