tuning question, just one
Old 04-01-2009, 10:22 PM
Swarthy Dago's Avatar
Ok something changed after installing a good aftermarket exhaust manifold.
scenario: Locked out of overdrive, then the torque converter locks up in third gear as it should, I've got too much smoke. Plate change or plate grind adjustment ? It surges too like a rocket. Oh one more thing, when over drive is allowed, the torque converter locks up as usual, and it runs perfect, just a haze of smoke and builds up to 30 psi of boost. When taking off from a stop, I get a small puff of smoke that I'm ok with. Thanks, Joe
Old 04-02-2009, 12:16 PM
BigErksG2's Avatar
sounds like an afc adjustment, move the housing back so you dont pour in the fuel until you build boost. maybe back the plate off a little (or your foot haha) to prevent exessive surging. interesting results you post, i would think a good manifold would reduce surging.
Old 04-02-2009, 03:30 PM
Thank you
Thank you BigErk. Seems like the direction to go. Makes sense to me because with better boost in high gear it goes away.
nasty01cummims
06-11-2009 08:56 AM
nottanuff03
01-13-2009 09:33 AM
Billm2004
12-26-2007 02:13 AM
Billm2004
12-20-2007 04:26 PM
Quick Reply: tuning question, just one
