tst surge help
Old 01-31-2008, 05:35 PM
Rpainter's Avatar
tst surge help
i just got my tst installed and took the triple dog off to see what differencr it does to the truck. with the tst on late twins,timing set to 3,rp set to 0 and hp on 3 and duration on 0. I get a surging at 1700 rpm to 2100rpm. Any way to help fix it?? Robert
Old 01-31-2008, 06:04 PM
UnrulyNFS's Avatar
I just press the throttle down a little more.
Old 01-31-2008, 06:39 PM
RamWheelsBy4's Avatar
If running the TST by itself why would you set the Timing to 3*?? Default is 12* Auto. I would set the Timing to 12* and try 3/1 or 3/2 with the 05tt program. I run my EZ on level 1 so you might want to turn the TST rp to at least 1. I have no surging with mine by itself or stacked.
Old 01-31-2008, 07:25 PM
Rpainter's Avatar
I will try to turn timing up and if I turn rp up the surging gets worse.I wanted to start low on timing since bigger injectors add timing by them selves
mjpalmer
05-19-2005 11:34 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
BLUTIC
18
04-17-2004 06:17 PM
Zino
08-15-2003 10:14 PM
Quick Reply: tst surge help
