tst power max 3 help
Old 02-17-2010, 03:38 PM
crash4wd's Avatar
i recently got powermax 3 and i cant get this thing to work i have read directions checked connections and this thing doesnt do nothing all lights on and it just doesnt feel there on the remote the green fuel light doesnt light up any ideas
Old 02-17-2010, 11:26 PM
pind's Avatar
sounds a lot like a bad connection at the VP, to be totally honest.
As long as you tapped the right wire, it "should" work. however, if you used the supplied scotchlock connector, it can go bad. I've had it happen a couple times on customer's vehicles.
double check that, and your boost pressure sensor connection. I am thinking one of those two is the culprit.
Old 02-18-2010, 08:42 AM
AggieJustin's Avatar
While you're looking at the lights on the front of the box (not the remote), do you see any change in intensity while you're driving? The green fuel light on the box should get brighter as boost rising and additional fueling is being delivered.
Old 02-18-2010, 02:20 PM
crash4wd's Avatar
on the box the green light doesnt really get bright it gets a little brighter but not much and it flickers alittle and i used the posi tap connecters
Old 02-20-2010, 04:25 PM
crash4wd's Avatar
ok well i took chip apart put it back on and now it works for about 30 sec and then its stops fueling everytime i unplug it will fuel for abou 30 sec does anyone have ideas
Old 02-20-2010, 07:31 PM
DIESELWRKS's Avatar
I would contact TST about it on the site they have alot of troubleshooting tech stuff
Old 02-25-2010, 02:56 PM
crash4wd's Avatar
i did they told me to tie the two egt wires together and that didnt work they are looking in to it i didnt know if anyone else had this problem
crash4wd
MDDTR #33
02-19-2010 05:46 PM
dieselman24
02-12-2004 08:33 PM
Mr. 45
08-28-2003 12:42 PM
Zino
08-15-2003 10:14 PM
hellotbone
26
02-07-2003 09:31 AM
Quick Reply: tst power max 3 help
