TST issues
Old 12-13-2004, 04:05 AM
forthcomingtwin's Avatar
TST issues
Okay, i dont know for sure what my problem is,so here goes---- im setting code 608 480 and 366. My truck will be driving along and die * KAPUT *. I will mess with the key on and off on and off for a minute or so. And it will then start. Wether or not it stays running is another issue. It does this consistently, i have astro start, i let my truck run for around 2 minutes, and then it dies.. the only way it will not calve on me is if im at around 2000 rpm or more. I can actually feel the truck start to defuel or whatever its trying to do. but it works its way past it-- at a high rpm level..... it has been doing this for 2 days now......
Old 12-13-2004, 08:39 AM
Mike S's Avatar
What I would start to do first is do the process of elimination, 1st pull off you EZ and see if that cures the problem, if not than put that back on and take the TST off and so forth. Have you checked your fuel pressure? Mike
Old 12-13-2004, 10:45 AM
cquestad's Avatar
That is a bad wireing harness...pull it off and send it back to TST.
Old 12-14-2004, 11:12 PM
wow, stock transfer pump
Old 12-15-2004, 11:53 AM
cquestad's Avatar
huh?
Old 12-15-2004, 03:05 PM
Kyle Graham's Avatar
Thats a bad ride I love my BD tranny and twins on my 01 Tst or edge will fix products. what mike said process of elimination
Old 12-15-2004, 05:42 PM
DTR Advertiser
Don M's Avatar
Sometimes the fuse taps will work loose. Power connection troubles are common.
Don~
mjpalmer
05-19-2005 11:34 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
Quick Reply: TST issues
