tst/ez stack?
tst/ez stack?
i stacked an edge ez on my tst pm3. with the boxes stacked the green light on my pm3 that shows it is adding fuel does not light up at all. any one have any ideas?
Is it hooked up like this? Map Sensor -> pm3 -> EZ -> stock connector. Make sure the switch is on for the pm3. Is the CANBUS connection connected right? Make sure the PM3 has power and the pump wire tap is still connected securely.
If you still can't get it, you're welcome to drive up here to columbus and I can take a look at it for ya.
brandon.
brandon.
brandon, i appreciate the offer for the help. while tracing wires i forgot about the inline fuse next to the 9pin connector. checked fuse and it was blown. replaced fuse and this thing rocks! lots more bottom end pull, with the box on 9 you can't tell if there is a car behind you for all the smoke if you step in it hard. i really like the stack.
Cool! I'm glad you found it. I've also had trouble with the 12v tap coming loose up by the firewall in the middle. Don't you just LOVE making those pesky tailgater's disappear?
brandon.
brandon.
Topper
03-03-2008 10:17 AM
mjpalmer
05-19-2005 11:34 AM
WhiteSport600
12-23-2004 09:59 AM
BCobb
07-11-2004 01:49 PM
Zino
08-15-2003 10:14 PM
