TST Competition???
Old 08-05-2008, 12:36 AM
Kman9090's Avatar
TST Competition???
Was just curious if this box fuels to 4000 rpm on a 2nd gen?
Old 08-05-2008, 06:52 AM
Ph4tty's Avatar
Mine only fuels to 3400 rpms.
Old 08-05-2008, 07:28 PM
ahire's Avatar
When i ran that stack mine would go to 3850. Tst comp on 6, Smarty on 7 or 9.
Old 08-05-2008, 09:06 PM
camododge's Avatar
Smarty on 5 and tst competition on 7 I could barely get 3500.
Old 08-05-2008, 10:17 PM
Kman9090's Avatar
Well i have been told havent tested it out yet, that the tst that my brother has on his truck will fuel hard to 4000rpm! And when i contacted tst about it that didnt say there were none out there that would but they didnt say that it wouldnt! They just kinda beat around the bush about it!
Old 08-06-2008, 12:52 AM
camododge's Avatar
Some trucks do, some trucks don't.
Old 08-06-2008, 08:15 AM
mcoleman's Avatar
There for awhile they advertised the comp to rev to 4500 on the website and then it was removed. Gilmore saw the website when it said that also. Not sure what was up with that.
Old 08-06-2008, 10:03 AM
98.5Hotrod's Avatar
It still says 4500 on their website, under FAQ.
Old 08-06-2008, 11:47 PM
cumminsboy's Avatar
Does the comp upgrade make a huge difference on the HO motor too, or just the So motor. Thinkin about sendin my PM3 off for the upgrade, but leery on the power it'll make. What do yall think?
Old 08-06-2008, 11:51 PM
AggieJustin's Avatar
From what I was told, the Comp upgrade didn't help much (if at all) on the HO pump as the regular TST wrings all it can out of that pump.
When I had my HO pump, I'd see no difference in HP on the dyno between level 5 and 9. After switching to the SO pump, based on the "seat of the pants" dyno, the upper levels make a much larger difference. Previously, I'd hit a max of 45psi...after switching to the SO pump I hit 50psi.
Old 08-07-2008, 07:46 PM
graphitecumnz's Avatar
on a stock HO pump you won't see the HP gain from the competition upgrade.
Old 08-07-2008, 10:32 PM
cumminsboy's Avatar
When i go to the SO i will though? One more question, will the Hod Rod and Monster vp's bolt up and work the same on an so and ho, or are those high dollar mothers for the so motor only
Old 08-07-2008, 10:59 PM
HR's and Monsters will go on either truck...
Old 08-08-2008, 06:50 AM
2whistlers's Avatar
If nothing else, you will already have it done in case you switch pumps. I think it's the best $50 you'll spend programming-wise. Not to mention you will get full fueling instead of having it cut back at 27 or 2800 RPM. Just my .02
Old 08-08-2008, 05:25 PM
cumminsboy's Avatar
Yea, heard that. That clears it up for me guys, thanks a bunch
Quick Reply: TST Competition???
