truck wont shut off
Old 11-17-2010, 10:17 PM
oldskool85's Avatar
truck wont shut off
I turn my key to turn off the engine today and everything turns off but the engine what could be the problem 92 ctd
Old 11-17-2010, 10:25 PM
Montana2x2's Avatar
Fuel shutoff solenoid stuck or rubber tip missing from plunger would be the first thing I would check.
Old 11-17-2010, 10:59 PM
oldskool85's Avatar
Where is that
Old 11-18-2010, 08:07 AM
DevilzTower's Avatar
The FSS (Fuel Shutdown Solenoid) is circled in green in this picture.
The lever circled in red is the manual shut down lever. This will kill the engine (regardless of FSS operation) if it is moved toward the cab (clockwise). When you hear people referring to the "pull cable" or "pull cable club" it means their FSS isn't working and they tied a cable to this lever to shut their engine down from inside the cab.
https://www.dieseltruckresource.com/...90&postcount=2
There is a place online you can get the FSS for cheap, I believe this is the solenoid ...
http://dieselvw.com/PumpSolenoid.htm
The older VWs use a variation of the same VE pump that we have on our engines, the shut down solenoid is exactly the same part. I replaced mine with the one on this website, now my truck will actually shut off. It's a beautiful thing.
Reference following thread for more in on procuring FSS ...
https://www.dieseltruckresource.com/...&highlight=FSS
Old 11-18-2010, 09:09 AM
92betsy's Avatar
By chance does anyone know a good method to get the solenoid out? Mine went out the other day and a tried taken a chisel to knock it loose and that didn't work. It made me to nervous I would screw it up. Should I grind that plate off that's in the way or is that a bad idea?
Old 11-18-2010, 09:16 AM
I think the recommended way is to grind the extra bracket out of the way so you can get at the fitting.
Old 11-18-2010, 11:06 AM
92betsy's Avatar
Ok I got it just used a cresent wrench and bent the bracket down. still had to remove the throttle linkage to do it but finally got it out and alot faster and safer then grinding it. but then the fss came out just fine.
Old 11-18-2010, 10:02 PM
Unless it's untaxed, then it's red.
#2isgreen's Avatar
it can be done without moving any brackets, you just get to turn it about 1/16'th of a turn at a time and use multiple crescent wrenches and channel locks. make sure you get the plunger and spring out, and reconnect the little plugs nice and tight.
dkimmel
01-03-2011 10:54 PM
randyswelding
02-09-2009 10:40 PM
Dean Snow
09-26-2007 03:40 PM
chromedome
04-10-2004 10:46 PM
dsljunkie
01-04-2003 09:45 AM
Quick Reply: truck wont shut off
