Truck wont run!!!
Old 08-19-2006, 06:26 PM
nvillagrana's Avatar
Truck wont run!!!
I have a 94 cummins and i cant get it to start? About three years ago i replaced the fuel transfer pump, heater/strainer, injection pump, and overflow valve. I changed the fuel filter today to see if it had gone bad and the truck ran fine for about 5 minutes and then when the filter ran out of fuel it died. So then i changed the fuel lift pump and filled the filter again with fuel and it ran fine for five minutes until it ran out and died. I checked the fuel shutdown solenoid and its working fine. Im stuck on what else to do, any opinions will help, Thank you.
Old 08-19-2006, 06:27 PM
Austin'sDodge's Avatar
Have you cracked the injector lines to purge the air from the system?
Old 08-19-2006, 06:33 PM
infidel's Avatar
Is there any fuel in the tank?
Don't trust the fuel gauge.
Old 08-19-2006, 07:02 PM
Yes there is fuel in the tank, and i tried bleeding air out of the system but still no luck
Old 08-19-2006, 07:05 PM
Dojman's Avatar
Again, out of fuel? I've run two out of fuel like that. Bad sending units.... Five minutes though, is a long time to run just on the fuel in the filter?
Old 08-19-2006, 07:11 PM
sorry the truck actually runs for about 2mins, i over estimated. Maybe there is no fuel, ill have to check and make absolutely sure.
Old 08-19-2006, 07:27 PM
I just checked and the tank is about half full
Old 08-19-2006, 08:18 PM
Dojman's Avatar
Well, the only things I can think of would be fuel lines(maybe a dry rot crack just got bigger?), hand pump/lift pump might have a problem, overflow valve maybe. Usually if it will run thirty seconds, mine will go on and stay running. I dont fill the filter, just pump the hand pump real good. Sometimes maybe fifty or more pumps.
Old 08-19-2006, 08:56 PM
I checked all the fuel lines they looked ok no leaks but i will probably end up changing them, lift pump is new and i primed it until my arm went numb(didnt help), i didnt check the overflow so ill make sure to do that also.
Old 08-19-2006, 11:29 PM
dodgetech77's Avatar
Like you looked in the tank or at he gauge?
Old 08-20-2006, 06:24 AM
plow's Avatar
Did all this trouble start after you changed the fuel filter this last time? I just don't understand 3 years ago you changed all that stuff and the truck ran good, then 3 years later you thought you would change the fuel filter and you started having trouble, seems to me if the truck was running before you changed the fuel filter this last time that is where I would start looking. All you need is fuel,timming,air,combustion for a diesel to run. If it is indeed running the filter out of fuel you either have a fuel restriction, no fuel at all or your leaking air somewhere. (i.e. the pickup tubes in the tank)
Old 08-20-2006, 05:03 PM
i looked in the tank plenty of fuel, it all started with a small leak from the banjo bolt above the fuel filter. I fixed that then it just got worse. It ran for one day after that before it just completely died. I changed the fuel filter after it failed. I thought it was the lift pump so i changed that again yesterday, still no luck. Also checked the overflow valve this morning and it was ok. This whole problem spans 2 days. First day was the leak above the fuel filter. Second day it ran ok for the day aside from difficult starting and at the end of the day it stopped running altogether.
Old 08-20-2006, 05:08 PM
mr T's Avatar
i know u mentioned the fuel shut off solenoid and said it was working fine but do check it again...check to see that it is staying up and not fallign down prematurely killing the motor...blue wire likes to corrode or fall off leading to it
Old 08-20-2006, 05:13 PM
ill look at the fuel shutdown again just to make sure
Stroked-Z
10-04-2008 11:28 AM
badley
11-15-2006 08:46 PM
farmboy56
10-27-2006 07:31 AM
coontz0473
10-04-2006 02:48 PM
Quick Reply: Truck wont run!!!
