Truck Wont Idle...
Old 11-20-2005, 06:27 PM
Burban35's Avatar
Truck Wont Idle...
96 Exe cab 4x4 Long Bed 12v #10 fuel plate.
Started up fine and drove maybe 50ish miles on the express way doing 70+ MPH and came off the highway and it stalled at the light so i try to start it nothing, Give it some fuel and it started right up but i had to keep it running, I tryed adjusting the idle and got it to run but it will only run Smooth in gear, Park or Neutral it will sort of surge anywhere from 500rpm to 2000rpm but if you put it in gear it will hold steady at 800ish RPM.
Any Help is Appreciated
Thanks Russ
Old 11-20-2005, 06:40 PM
MnTom's Avatar
Overflow valve problem? Try looking here: Engine Diagnostics You might find something there that helps.
Tom
Old 11-20-2005, 07:00 PM
Burban35's Avatar
I don't know if this helps or anything but i JUST toped off the tank well 30 gallons of Dyno Diesel and the previous tank was Off Road Diesel. I don't know if that hurt anything or its Hopefully just an overflow problem.
Old 11-20-2005, 07:42 PM
infidel's Avatar
Check that your shutdown solenoid is pulling all the way up and that your throttle linkage hasn't fallen apart.
Off road fuel is no problem
Old 11-20-2005, 07:52 PM
Crimedog's Avatar
Maybe governor springs? I noticed since I turned mine down a couple clicks that I can't get it to hold between 1100 and 1600 RPMS, it is either lower or higher. Just throwing out ideas here...
Old 11-21-2005, 10:13 AM
Burban35's Avatar
Well i messed with it a little this morning and in still can't get it to hold steady Unless i have the idle screw to low and i have to give it some fuel to start thats the only way i can get it to hold at any RPM in gear or in Neutral or Park. Could that be a sign that its the Over Flow or something else?
Old 11-22-2005, 07:05 PM
Burban35's Avatar
Well i think i found the problem, I went out and bought some Diesel Clean (Diesel 911) and dumped the whole thing in there went to the gas station and mixed it with maybe 2 gallons of fuel and the Idle doesn't flucksuate(spelling) At ALL anymore. I guess cause of the temps changes around here lately (25 Degrees Currently) that must of done it. Oh well lessoned learned have to add some kind of cleaner or ANTI GEL substance Every time i fill up.
Thanks For Looking
Russ
rustydeeretech
06-16-2010 09:41 AM
kyle_truck_pull
03-18-2009 09:08 PM
Stroked-Z
10-04-2008 11:28 AM
Rpainter
07-21-2007 08:48 AM
qcstunter
01-09-2007 04:10 PM
Quick Reply: Truck Wont Idle...
