truck wont idle down when hot????
Old 07-19-2007, 08:52 PM
Rpainter's Avatar
My boss has a 2003 with a 6 speed manual trans when the truck is up to normal operating temperature and he comes to a stop light the truck idles at 1200 rpm with the clutch pushed in?? It has been to 3 different dealers and they say the truck is fine?? Any ideas?? The truck is bone stock
Old 07-20-2007, 11:50 AM
elirandolph's Avatar
I believe that there is something in the computer that if it senses really hot temps or real low temps it Idles it up to 1000 RPM. I have never heard of 1200 RPM though. Maybe a temp sensor, computer needs to be flashed, or maybe something with the fan clutch. Just throwing some ideas out there.
Eli
Old 07-21-2007, 02:14 AM
Bark's Avatar
For what its worth, my 03 6speed has never done it.
Old 07-21-2007, 06:47 AM
CG98x's Avatar
Might be the FCA sticking mine does it to. Can you get it to idle down by stepping on the brake pedal hard or letting the clutch out lightly while not moving. If it idles right down I would bet on the FCA.
Old 07-21-2007, 07:04 AM
Rpainter's Avatar
I will check with him monday
Old 07-21-2007, 08:48 AM
MikeyB's Avatar
First check the FCA. Take it off, shake it and see if it rattles. If it does, should be ok. Next check the APPS (Accelerator Pedal Position Sensor). On the '03 it can be found either on top of the CP3 (under the rounded plastic cover) or under the driver side battery.
MikeyB
whosdunit
02-16-2019 04:07 PM
rustydeeretech
06-16-2010 09:41 AM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: truck wont idle down when hot????
