truck topper/cap compatibility between 2rd and 3rd gens?
Old 01-01-2010, 10:20 PM
upjeeper's Avatar
anyone have any idea if a truck topper will easily go from a 2nd gen to a 3rd gen short box?
thanks
Old 01-01-2010, 10:23 PM
ripping r's Avatar
hay i was woundering this same thing. found a nice 2nd gen shell. but nobody knows if it will fit.
Old 01-01-2010, 11:04 PM
cLAYH's Avatar
I have one that I share between my '01 and '03 as the need arises. Its designed for the '01 but fits the '03 no problem. However it doesn't look quite right.
I don't care though, it only goes on for a specific task then comes back off. If you are concerned about looks and plan to leave it on permanently you'll probably want to find a 3rd gen specific topper. If you just want to throw it on occasionally to haul garbage it will work fine.
Old 01-01-2010, 11:05 PM
cLAYH's Avatar
BTW this is for a long box. I would guess that a SB would fit about the same Unless you have a mega cab as that has an odd ball box length.
Old 01-02-2010, 07:57 AM
sabersix's Avatar
3rd Gen Mega Cab and Quad Cab short bed use exact same bed. Caps are interchangable.
Not sure about 2nd Gen to 3rd Gen though.
Old 01-02-2010, 11:37 AM
cLAYH's Avatar
My bad. I could have sworn the Mega Cab used a 6 1/2 foot box or something like that.
Thanks.
Old 01-03-2010, 07:31 AM
Dodgezilla's Avatar
Short bed QCs and MCs are the same size. 6.5' long
The caps will interchange between 2nd gens and 3rd gens but they are slightly different sizes. It doesn't look bad but it's not a perfect fit. I did this when I sold my 98 truck and bought an 03 truck.
Old 01-03-2010, 03:28 PM
stickk's Avatar
I think the 2nd gen box, short beds, is about an inch or so longer than the 3rd gen. So it should work but as stated previously, it won't be a perfect match. I am currently using an ARE utility top that was on a chevy sb on my mega cab. It isn't perfect but the price was!
Old 01-04-2010, 06:49 PM
upjeeper's Avatar
some decent info regarding compatibility
http://www.pace-edwards.com/applications/JRApp.pdf
Trebor
12-23-2006 12:17 PM
AK RAM
08-02-2005 07:45 AM
AK RAM
21
08-01-2005 12:16 AM
Micaiahfied
07-12-2005 09:51 PM
Quick Reply: truck topper/cap compatibility between 2rd and 3rd gens?
