Truck stays in top gear/no od
Old 01-14-2008, 12:46 PM
downlow's Avatar
From a dead stop take off Im already on top gear with no OD. Sometimes I can stop the truck, put in park, turn off then restart and it shifts normal!!!!???
When it doesnt work Im stuCK with 1 gear and 2000rpm at or around 52 mph. Diesels already to dam expsensive so I if someone has the fix well it sure would be appreciated. BTW its a ATS trans with a Goerends TQ.
Old 01-14-2008, 05:40 PM
downlow's Avatar
Come on!!
Come on fellas this isnt a case of "it wont run" but I still consider double fuel usage a emergency .ANY IDEAS?????
Old 01-18-2008, 06:52 AM
downlow's Avatar
Bump
Speed sensor.....TPS.....?????
Old 01-18-2008, 07:18 PM
Fred Swanson's Avatar
Sounds like limp mode, you get 3rd gear only. Could be Gov Trans or Solenoid too.
Old 01-19-2008, 12:14 AM
fletcher359's Avatar
Mine does somthing similar but it will stick in od when you come to a stop. If i dont downshift manually it'll shake like an earthquake. But once the tranny warms up it'll stop, its in bad need of a rebuild!
CTD NUT
Off Road / 4x4
10-20-2007 01:57 PM
Dean Snow
09-26-2007 03:40 PM
irish4u
12-03-2005 10:23 AM
Quick Reply: Truck stays in top gear/no od
