PDA
View Full Version : Truck pull in Arpin Wisconsin on BLACKTOP
Bobcat698
08-07-2005, 02:23 PM
Yesterday was the truck pull in Arpin Wisconsin.
It was held on blacktop and we were pulling 45,000 pounds. Basically they shut off a section of road that led to the park.
The sled was not self propelled, they pulled it back with a tractor each time. It had wood blocks in the front that it rode on. The axles made the weight box travel.
There were a good 75 or more trucks that showed up... Anything from Hobby 2x4s, 4x4s, old farm trucks and more. They pulled the diesel pickups last.
There were around 6 Dodges, 2 Duramax's, and 2 Powerstrokes. An 8.1L 2500 GMC also showed up and pulled in our class.
I weighed in at 7900 with some sand in the back.
One of the Duramax's has over 500HP at the wheels. He made it about half way down the 250 foot track and just started smoking the tires. There was black smoke on one side of the truck and white tire smoke on the other side
I made a full pull, I thought something had snapped when the weight box HIT the front of the sled!
The only other person that did was running a 95 regular cab Powerstroke.
He had his hitch set up in a unique way.. He had a coupler connected to his gooseneck ball in the bed, then had a hole cut in the bed and the bar ran down back towards where the normal hitch height is. Basically made a lot more weight be put on the front of the truck as well. He took first place in 3 classes (he was allowed to run in lighter weight classes. (this type of hitching isn't allowed at most places)
We ended up pulling off.. I pulled 103 feet and the Powerstroke pulled 117 feet. I took second and a $75 check
My pulls are getting consistently better:cool:
I took these places in this order: 5th ($10) 3rd ($20) 9th (intercooler boot blew off) and 2nd ($75)
I LOVE THIS TRUCK
It was a blast!
I will post some videos soon!
PourinDiesel
08-07-2005, 02:26 PM
Blacktop!!:o
Bobcat698
08-07-2005, 02:53 PM
Originally posted by PourinDiesel
Blacktop!!:o
Yep! Only saw a couple instances of carnage. A few u joints and a rear end.[eyecrazy]
TxDiesel007
08-07-2005, 02:59 PM
Scary..
glad u made it out OK.. i wouldnt pull bumpers on blacktop, much less sledpull.... congrats tho!
Tx
Bobcat698
08-07-2005, 04:52 PM
Originally posted by TxDiesel007
Scary..
Tx
Speaking of pulling bumpers.. I'll have a thread on that soon:o
fahlguy
08-07-2005, 08:12 PM
BLACKTOP!!!!!!!
durasmack
08-07-2005, 11:09 PM
ive seen dirt strips end in blacktop and ive seen trucks run right off the dirt with the sled....... never seen one start on blacktop though :confused:
Bobcat698
08-08-2005, 11:48 PM
Here is the video of me doing a FULL pull!
Garrett, Full Pull, Arpin Wisconsin August 6th (http://www.blackclouddiesel.com/Videos/gsfparpin.avi)
More videos coming later!
satburn
08-09-2005, 12:06 AM
Nice.... what was that rpm change right when your front wheels got to the end of the track?
Bobcat698
08-09-2005, 12:25 AM
It shifted back into second gear.
Fueling around
08-11-2005, 11:24 PM
The hitch setup used by the stroker is similar to the ones used for semi pulls. Local guy has a version that hooks to the gooseneck ball, runs straight back and a vertical piece connects to the receiver hitch. Real handy to distribute the load and get a 26" hitch height.
Nice turbo bark at the end of the pull.
Bobcat698
08-12-2005, 01:04 AM
Exactly:D
Trying to kill the stock turbo so I can get my H2B2:rolleyes: [laugh]
TxDiesel007
08-13-2005, 02:20 PM
Awesome video
and smoke garrett!! Cant wait to see the rest of them....
Tx
wings
08-14-2005, 07:49 AM
I got a question on these pulls on pavement. I'm not a puller but an old time drag racer.
It would seem to me that you could get a pair of 34 x 17wide x 16 drag slicks (used about $200) and make some rims since none are availabel for the 8 bolt. I'm sure you would have to screw them to the rims and run a bit more pressure that the drag guys do. On 3500 drw with a 6 spd (strength). Add what ever weight is permitted to the bed. Then just start out in 1st and run up to just under defuel and let it pull. Speed not being the issue that it seems on dirt. I watched the local farm tractor pulls and some of those big ol' tractors just crawl along. whataa ya think.???
At anyrate I would think drag slicks would be the norm here especially on the 4 x 4.
bentwings
mikmaze
08-14-2005, 08:59 AM
dayum now thats some serious smoke, nice pull.... did ya happen to get an egt reading near the end of the run?
cumminsdriver635
08-14-2005, 02:06 PM
Nice video! Must have been a pretty built stroker to beat you. How do you like your mojave green converter? Sounds like it was really putting the power down.Did you buy it on ebay. if it holds well for you i might have to look into one. Is your tranny stock other than that and the transgo? Im also interested in what your EGT's were. The smoke looked awesome:D Keep the videos coming:D
Eric
Bobcat698
08-14-2005, 04:18 PM
The Stroker was hardly built.. It was the hitch setup that allowed him to do so well. It put a lot of the weight on the front axle.
So far I've been happy with the torque converter.. no slippage that I noticed yet. It came installed in the truck when I bought it.. Other than the stock rebuild and transgo, thats all that is in it.
Boost hits about 40 to 43 PSI. EGT's get to about 1800 at the end of the run IIRC
cumminsdriver635
08-14-2005, 11:02 PM
So are you running stock injectors? Thats about the smokinest thing i've ever seen if u are.:D
Eric
Bobcat698
08-15-2005, 09:20 AM
Completely stock injectors:D
Its all in the delivery valves:cool:
Bobcat698
08-15-2005, 05:18 PM
Here are a couple more videos:
PULL OFF, MY TRUCK (http://www.blackclouddiesel.com/Videos/gspulloffarpin.avi)
Duramax (http://www.blackclouddiesel.com/Videos/dmaxarpin.avi)
Powerstroke, Pull off against me (http://www.blackclouddiesel.com/Videos/pspulloffarpin.avi)
cumminsdriver635
08-15-2005, 05:51 PM
Well those delivery valves are sure gettin the fuel out anyway.[laugh] That D-max was funny, and that ford didnt have much power didnt look like. Just had the most traction. Nice videos
Eric
TxDiesel007
08-15-2005, 11:10 PM
Eric
yeah no kiddin.
i thought it be a 99 and up...., the duramax, well just showed alot of heart and effort, and worthless differentials. [laugh]
Tx
