Truck Will Not Start
Old 11-22-2009, 07:53 AM
dodgeman5902's Avatar
Unhappy Truck Will Not Start
Hey Everyone,
Yesterday I was hooking up my utility trailer and had truck running.
When I got into the truck to align it up, it stalled. It was like I had released
the clutch too quickly and choked it down. Now all it does is turn over and will not start up. Has anyone ever had this problem or any ideas what it might be?
Old 11-22-2009, 08:25 AM
mini14's Avatar
Bad fca, bad rail pressure relief valve, leaking injector(s), bad cp3, low fuel pressure.
1 or more could be the cauz u have to start narrowing down. id start with checking your fuel pressure.
Old 11-22-2009, 08:47 AM
mini14,
Do you need any special tools and are they expensive?
Old 11-22-2009, 09:51 AM
mini14's Avatar
first check 4 any codes, key on off 3 times, then check your fuel pressure with a guage, if your under 100k u should still be under warranty. remove the module and c if it starts. Then tose the k&n in the garbage and get something better on, or the stock air box.
Old 11-22-2009, 11:34 AM
already checked for codes and it passed, no codes
Old 11-22-2009, 12:16 PM
mini14's Avatar
unplug the module, if it still doesn't start, cap the rail pressure relieve valve at then try to start it. u must check your fuel pressure before doing anything.
TXJClark
12-06-2014 05:50 AM
Hunky Dory
05-13-2013 08:09 PM
FirstGen1991
12-22-2012 04:24 PM
CoolumConst
10-11-2008 10:00 PM
loosendend
09-04-2006 12:01 PM
Quick Reply: Truck Will Not Start
