truck missing
Old 11-11-2003, 05:39 PM
moneyman's Avatar
truck missing
WHen I stomp on her and shes pulling hard it feels like shes coughing or studdering on the way up the rpm scale. I've got the hx40 ddIII's comp with wire pierced. Any suggestions?
Old 11-11-2003, 05:42 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Re:truck missing
What are the gauges reading? Especially fuel Pressure.
Old 11-12-2003, 09:44 AM
moneyman's Avatar
Re:truck missing
fuel pressure is reading 9 psi wot
Old 11-12-2003, 10:34 AM
Shovelhead's Avatar
Re:truck missing
I'd try cleaning all the electrical connections from the "Box" to the harness/sensors as a first step.
Especially the MAP sensor near the fuel filter canister.
Old 11-12-2003, 03:03 PM
HOHN's Avatar
Re:truck missing
Truck missing? Did you not install a lo-jack? ;D
Justin
Old 11-13-2003, 10:29 AM
moneyman's Avatar
Re:truck missing
problem fixed. The scotch lock was a little loose on the pump wire. Crimped her down tighter and everything went away.
Jason
Old 11-13-2003, 12:49 PM
Rattletrap1's Avatar
Re:truck missing
Scotch-loks are junk.
Old 11-13-2003, 01:24 PM
gandrews's Avatar
Re:truck missing
I don't disagree.
What are better options for tapping the pump wire?
Old 11-13-2003, 04:14 PM
MCummings's Avatar
Re:truck missing
Blue Chip Pump Cover.
I think about $60-$70.
www.bluechipdiesel.com
Merrick
P.S. Or solder it in, but those wires are a major pain to get to.
razor6
07-13-2006 12:23 PM
crittergetter
26
10-28-2005 05:15 PM
bigair
04-26-2005 08:26 AM
yrusoslow2
11-11-2003 07:58 PM
Quick Reply: truck missing
