truck giving CEL
truck giving CEL
showing P0500, P1594, and the generic p1693.....
truck looses pedal, but it comes right back, CEL clears after cycling switch 2-15X
thanks in advance
thanks in advance
P1594 is charging system voltage too high.
P500 is no vehicle speed sensor signal. (you can also get it by spinning the rear wheels)
P1693 - companion code in ECM
Loose your tach at all? if so, look at cps
Tach seems solid, i have noticed, that my truck seems like it is "hunting" gears while cruising on flat terrain @ speeds between 40-60 mph...Also forgot to mention, i have good fuel pressure 12psi cruising and around 8-9 @WOT
due to the fact that my truck was "hunting" gears, i cleaned all my grounds, w/exception of the two under the head-liner...i think there were 15-16 other grounds, i also ordered and installed the "timbo APPS" replacement...and i believe this has rectified my CEL issue, as it has not occoured in over a week (was happening daily) ...i also replaced both neg. batter clamps while checking/cleaning my grounds...i have not had the p1594 code since....
had several people tell me that the "APPS" would not throw a "CEL" well i believe it was the cause of the error code, time will tell, but for now i'm making smoke with out concern
MrSuzuki
06-16-2009 12:23 AM
boaterman
10-15-2008 10:44 AM
Hillbilly Delux
03-20-2008 05:01 PM
Ripper406
04-06-2005 07:38 PM
