Truck Died Tonight
Old 07-25-2010, 10:31 PM
Fallguy's Avatar
Truck Died Tonight
'02 2500 Auto died like turning the key off 86,00 miles, year old injector and lift pumps, no fuel in filter housing, has 1\4 tank won't even try to start,lift comes on momentarily when key turned to on Where do I start ?
Old 07-25-2010, 10:53 PM
maroonbeast01's Avatar
mine did the same to me crusing down the freeway. I first checked to make sure i was getting fuel at the fuel canister on the side of the block and when it was i cracked number 1 and number 3 injector to see if they were getting fuel. also you could take and turn the key on/off three times and look at the odometer window and see if any codes pop up i dont mean to jump the gun but souds like a vp44 went south thats what happen to mine.just my .02 cents
WestTN's Avatar
Fuel level sending units have sometimes fallen apart and reading 1/4 tank when it is actually empty. Try putting some fuel in.
Old 07-25-2010, 11:01 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
I agree fuel level sensors are notorious for being off 1/4 tank. Try putting 5 gallons in tank then bump starter a few times until you have fuel coming out the overflow valve in injection pump. Tighten that up then loosen a few injectors lines until you see fuel there.
Old 07-26-2010, 09:59 PM
Fallguy's Avatar
Thanks for the tip. I've never been so happy to be out of fuel in my life. 5 gallon in the tank 1/2 gallon all over everywhere and she rattled to life.
Old 07-28-2010, 01:17 AM
KATOOM's Avatar
Be careful. Do that more than once and you will be replacing that VP. They dont do well running on no fuel.
Old 08-01-2010, 01:03 AM
Fallguy's Avatar
Is there a 'better than stock' replacement sending unit ?
Old 08-01-2010, 01:21 AM
wyododge's Avatar
Had the same thing happen to me, I was lucky enough to roll into a fuel station though. Filled it up and immediately logged onto DTR when I got home. I took my bed off, and after going round and round with the dealer about a replacement decided to clean it and check the resistance. I was able to get the resistance levels from the dealer. Made sure the contacts had good connection all the way through the sweep before I re installed it. It works fine now, although I must admit I very rarely if ever let it get much below 1/3 of a tank now.
There is supposed to be a replacement sending unit, and not the whole dang canister, but from what I have found it depends on the dealer in your area for the oem sender replacement. I have seen aftermarket sets but I think you have to get a separate gauge. Kind of a drag to say the least.
You can try searching sending unit. you might actually be able to find a part number. Seems to me I found it after I fixed mine.
HTH
Old 08-01-2010, 07:23 AM
Junk Man's Avatar
MANY aftermarket replacements. More reading than you will want to do. All you have to do is pick something (other than the in-dank replacement) AND get gauges. Perhaps gauges and a light is better because you can't watch gauges all the time and a light would call attention.
Old 08-01-2010, 09:37 AM
duster75's Avatar
I've got the stock p.n for the fuel gauge sending unit around here somewhere. I assume thats what you are looking for? If so,I'll find it and post. Nate
Red3quarter
08-14-2008 08:13 PM
realsquash
38
12-19-2006 09:14 AM
Dusty Ratcliff
05-20-2006 08:53 PM
timb
01-08-2006 11:54 AM
jd03ctd
19
11-14-2003 09:00 PM
Quick Reply: Truck Died Tonight
