Truck cranks but wont start
Old 04-22-2011, 07:22 PM
braap736's Avatar
Exclamation Truck cranks but wont start
I took the edge tuner off a month ago and haven't started it since. Now it just cranks but won't start. It acts like its not getting fuel. Is there something I could have done when removing the tuner or did it lose its prime from sitting so long. Need help asap thanks
Old 04-22-2011, 10:56 PM
rockcrawler304's Avatar
Unlike the older diesels, your 06 will not really lose its prime. If you have cranked it a few times the pump will have pressurized to system.
When you first turn the key to the ON position, can you hear the pump in the tank make a buzzing noise? If you "Bump" the starter you will hear the pump run even longer.
Old 04-23-2011, 12:41 AM
braap736's Avatar
Ok also a couple days before it was parked it threw a crankshaft position sensor code which I cleared. It never ran rough before so I figured everything was ok. I'm wondering if that's the issue
Old 04-23-2011, 07:32 PM
Sur5er's Avatar
I believe you done broke the code! All you did was turn out the light. You either have a bad CPS or wiring. I'' check the connections first. If the CPS has gone TU, or the wiring is broken, then the ECU is waiting for a signal to start the injection sequence. No signal, no juice (Diesel)!
Old 04-23-2011, 08:34 PM
braap736's Avatar
Cool that's what I'm hoping, the sensor will be here tomorrow so ill let you guys know
Old 04-24-2011, 01:33 AM
Sur5er's Avatar
Hey, you have to remember that without actually checking the CPS or pulling the codes, we are really making a SWAG at what the problem really is
Old 04-24-2011, 10:35 AM
braap736's Avatar
Yea I understand that. I put a new csp sensor in and it made no difference so its going to a desiel repair shop cause I'm close to lighting it on fire
Old 04-25-2011, 06:17 PM
braap736's Avatar
Well two different dealers can't figure it out,!they said there scan tool is not seeing any signal from the ecm or pcm. I think I might light this truck on fire
Old 04-26-2011, 01:07 PM
braap736's Avatar
Well its the fan clutch. It has a short that won't allow the pcm to power up. Great design
braap736
04-26-2011 02:37 PM
JG_DIESEL59
05-08-2010 11:22 AM
berettaman
09-11-2009 08:07 PM
Silver 002
20
02-18-2008 03:34 PM
screaminbanana
08-25-2005 09:30 AM
Quick Reply: Truck cranks but wont start
