Truck "bucking" w/ Quad boost fooler
Old 01-07-2008, 06:22 PM
Big Smoky's Avatar
I have a Quadzilla boost fooler with my Power Puck and I've been noticing when I put it on the 90 HP setting the truck will buck under any mount of throttle. It throws no codes and runs fine on all the other settings. Any suggestions? Thanks
Old 01-07-2008, 06:47 PM
sliqwille04's Avatar
I'm not familar with the power puck, but if it plugs in the map sensor like an mp-8 or any module, try changing the order they are plugged in ie, fooler first, then module, then stock, or module, fooler then stock. The puck might have a slight boost fooler on it as well, but I'm not sure. Maybe this will help?!
Old 01-07-2008, 07:23 PM
Big Smoky's Avatar
Thanks for the reply. The Puck is just a pressure box, but I don't think it has any boost fooling as far as I know. I might switch it up and see what it does. I read somewhere though to plug in the BF and then the Puck, so I don't know.
Old 01-07-2008, 07:32 PM
LFD2037's Avatar
I know the BF is good w/out a doubt in my mind. If you are not using the tap, maybe take it off & tape it up? The BF should be plugged into the engine side, then the puck plugged into the BF then the puck plugged into vehicle wiring harness that goes to the ECM. If it won't work like that, then take the BF off & try just the puck on 90 for a little while. If it still does it, you have the wrong puck more than likely. ALOT of people had issues w/ the puck not working on their year truck even though it said it was for that year. Also try diablosport.com forum. HTH
Old 01-07-2008, 07:42 PM
Big Smoky's Avatar
Yeah, I think I might try taking the BF off and see what happens. It may very well be the Puck. Thanks for the help
jmccart
04-05-2011 06:13 PM
Killdmycobra
11-12-2010 05:15 PM
wap
15
08-17-2007 11:53 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
Quick Reply: Truck "bucking" w/ Quad boost fooler
