trouble code
Old Aug 18, 2006 | 09:46 PM
dieseldodge's Avatar
trouble code
anybody had a P0237 (turbo boost sensor A circuit/ low input code kick. if so what ya do to solve it.
Old Aug 18, 2006 | 09:55 PM
blackdiesel's Avatar
Registered
0237 map sensor voltage too low- check the map plug low input voltage BTW welcome to DTR
Old Aug 18, 2006 | 10:00 PM
thanks man, where is the sensor at.
Old Aug 18, 2006 | 10:03 PM
Registered
it's above the fuel filter in the head twards the back. you can go to the edge site and see a photo if needed
Old Aug 18, 2006 | 10:11 PM
thanks for the help, bro
Old Aug 18, 2006 | 10:38 PM
Registered
did you find it? i tried looking for a pic, but couldnt find one. ill look harder if you need it still.
its straight back from the fuel filter. plugs into the side of the block. Only thing within 10 inches that remotly looks like a plug. good luck
Old Aug 18, 2006 | 10:43 PM
yea i found it and i feel like an idiot, i knew where it was at, i wasnt looking for an electrical boost/map sensor. i was thinking of an old gas motor set up. hell, i installed the edge comp and i had to install the the subharness on the map sensor. i pulled up the installation instuctions and found a pic of it to refresh my memory. thanks for all your help.
Old Aug 18, 2006 | 10:47 PM
Registered
you bet
ridlangus123
Dec 30, 2013 08:36 PM
j
Mar 9, 2004 11:45 AM
fitzer
Mar 7, 2004 07:09 AM
sawboywv1
Jan 5, 2004 04:42 PM
dansdodgediesel
Jan 2, 2004 04:30 PM
