Trouble code P0341
Old Oct 12, 2007 | 09:29 AM
Striper's Avatar
Trouble code P0341
Had my yellow engine light come on yesterday for a little while. Did not stay on too long. Ckecked for codes. P0341 came up. Anyone have a clue what this code means?
Old Oct 12, 2007 | 02:46 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
It's a cam sensor error code. have you degreased or washed the motor recently?
Chris
Old Oct 12, 2007 | 08:30 PM
Striper's Avatar
No. Not at all.
Old Oct 16, 2007 | 08:42 PM
Striper's Avatar
Okay. The truck has not been washed or powerwashed at all lately. The light has not come back on since last week. Should I clear the code or just leave it be?
Old Oct 16, 2007 | 09:01 PM
wreedCTD's Avatar
if the problem has corrected itself the code should clear itself.
Old Oct 18, 2007 | 11:13 AM
98xc800's Avatar
Mine threw the same code last winter, after the engine failed to start at 30 below zero (block heater falfunction). The code would not reset (even pulled battery cables off for several hours), and had to be cleared by scantool. It hasn't re-occured, but I have a spare sensor in the glove box just in case.
Old Oct 12, 2009 | 12:00 AM
Pizipe's Avatar
Chris
I found this post while searching the answer to a problem I'm having. I have a p0341 code and have tried replacing the cam position sensor, no luck. Then I spent an hour on my back wire looming and taping the wires that rub the AC compressor, no luck! I just a had a cam installed and the engine WAS pressure washed due to an oil leak that had gotten everywhere. Why would pressure washing the engine cause this code, and how can I fix it?
Old Oct 12, 2009 | 12:14 PM
Pizipe's Avatar
This killing me, please somebody that knows about this stuff... take a look!
Old Oct 12, 2009 | 03:56 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Water gets forced into places it isn't supposed to be when you use a pressure washer, bad mojo for a diesel engine... check EVERY plug and connection and clean with Electrical cleaner. Putting a little dialectric grease on the plugs before putting them back together can't hurt either.
That is where I would start.......
coope3
Dec 15, 2008 02:39 PM
Steve V.
Nov 30, 2008 03:10 AM
dieselguy01
Aug 19, 2008 02:16 PM
98xc800
Mar 12, 2007 06:41 PM
GaDawg
Feb 26, 2006 02:42 AM
