Triple's anyone?????????
Old 09-12-2009, 01:51 AM
Bswope's Avatar
http://s190.photobucket.com/albums/z...nt=Triples.jpg
Two vid's in there too......
Hmmm........
Old 09-12-2009, 02:27 AM
DTR question asker
dieselfuelonly's Avatar
That sounds so good
Old 09-12-2009, 10:00 AM
s'port diesel's Avatar
I wonder what the numbers are? It almost looks like if the entry of the airflow was at an angle, rather than 90 degrees it would be more efficient at building boost. Just a thought. Still sounds really good.
Old 09-12-2009, 10:09 AM
53 willys's Avatar
Dyno..
Old 09-12-2009, 10:12 AM
Not a member there, it won't let me view it.
Old 09-12-2009, 10:45 AM
OldSmokey's Avatar
710 fuel only 50 psi boost
Old 09-12-2009, 10:48 AM
sdguy55's Avatar
I have to wonder if that is that effiecent of a setup. Two turbos feeding one is alot of money. I wonder what the results would be if he had done a procharger feeding a turbo. You would get instant off the line boost, at the sacrifice of some parasitic HP but the gain would still have to be over 30% gain in HP
Old 09-12-2009, 10:54 AM
Bswope's Avatar
Its actually 1 turbo feeding 2.......
Old 09-12-2009, 11:04 AM
jiggerman78's Avatar
that sound is rediculous...Anyone know the turbo sizes?
Old 09-12-2009, 11:06 AM
Bswope's Avatar
Id like to know as well, if im right on it being 1 feeding 2, then the manifold charger (i would think) would be bigger than the two primaries....
Old 09-12-2009, 01:36 PM
sdguy55's Avatar
Well then i really dont know why you would do that...whats the advantages to having 1 turbo feeding two? Although i dont know what this 'manifold charger' is that you mentioned so that might make a big difference.
Old 09-12-2009, 02:02 PM
CamperAndy's Avatar
Your looking at drive pressure. The other guy is looking at compression. I look at it as two feeding one as compression is the objective.
Old 09-12-2009, 02:17 PM
stroker101's Avatar
that's SICK!!! I LUV IT, LOL!
Old 09-12-2009, 02:36 PM
megacabdad's Avatar
That thing burns really clean for having over 700 hp!
Old 09-13-2009, 08:04 AM
Bswope's Avatar
Your right, I'm looking at it as the manifold charger is feeding drive to the two primaries.... and then the two primaries are feeding the one... just depends on how you look at em I guess......
Quick Reply: Triple's anyone?????????
