trany shift question
Old 11-25-2011, 12:51 AM
oldblues's Avatar
Question trany shift question
hi
a friends 97 stock trany will shift 1 to 2 fine but does not shift to 3 rd without moving shift lever to N then back to drive then it shifts into 3 rd ?
no slipping when in gear !
just replaced the solinoid pack and gov pres sensor !
recent new tps .
none of these items seem to help ?
any ideas ??
thank you !
Old 11-25-2011, 01:08 AM
green95's Avatar
Aren't the solenoids for OD and TQ lockup?, I hope you guys did the general fluid/filter change and band adj. I don't have my service manual inside, I'l get it in a few hours and check the troubleshooting for 2'nd to 3'rd shift and post it up for you.
Old 11-26-2011, 06:19 PM
oldblues's Avatar
yes new fluid ,filter and no codes ?
Old 11-27-2011, 09:36 AM
j-fox's Avatar
Pressure testing with gauges will help, but I'm guessing the front cluch seals are leaking, delaying the shift. Very common in those years.
Old 11-27-2011, 11:41 AM
cj360trider's Avatar
green95 jus a side note. don't forget ur 95 has a 47RH and the 97 has a 47RE they're the same but different LOLOL
Old 11-27-2011, 06:19 PM
green95's Avatar
I cant find my manual,I'm still looking,Man gettin senile already lol
Old 11-28-2011, 07:31 PM
green95's Avatar
All indications are the Gov.assembly or clogged filter,But you changed those. Book suggests looking at your linkage for binding or Adj.issues.... sometimes it's the simple stuff
winkdemon
09-22-2008 09:18 PM
A_Manke
02-12-2008 11:08 PM
Greguw
11-20-2005 10:18 PM
bigfoot
10-08-2002 04:17 PM
Quick Reply: trany shift question
