Transmission service around Boise, Idaho
Old 02-15-2010, 11:39 AM
ID2500Ram's Avatar
Looking for a reputable private shop to do transmission service on my 06 with 48RE automatic. What transmission fluid is commonly used at private shops?
Old 02-15-2010, 12:29 PM
Pull Ya's Avatar
If they try to use any fluid other than ATF+4 go to another shop.
Jay
Old 02-15-2010, 01:42 PM
ID2500Ram's Avatar
I know the Mopar fluid is called ATF+4, but do the aftermarket fluid makers also make one called "ATF+4"? thanks
Old 02-15-2010, 04:07 PM
JTaylor's Avatar
I've heard nothing but very positive feedback about Ultimate Transmission in Boise. http://ultimatetransmission.com/Home_Page.html
Old 02-16-2010, 03:39 PM
DBLR's Avatar
The only AFT fluid I would use are Mopar, Valvoline and Amsoil synthetic ATF.
Old 02-17-2010, 08:47 AM
cbrahs's Avatar
pm sent
Old 02-17-2010, 12:35 PM
Pull Ya's Avatar
I think that ATF-4 is a copyrighted brand name. I think there is a list floating around somewhere of other manufactures that have been approved by Dodge to use the ATF-4 name once their fluid was proven to meet Dodge's spec's.
http://www.centerforqa.com/home.html
Jay
Old 02-17-2010, 02:30 PM
DBLR's Avatar
Jay
You are correct but I would still not use off brand names and would stay with proven names like I know and trust Mopar or Valvoline and Amsoil if you want 100% synthetic ATF.
Old 02-17-2010, 03:55 PM
Dr.Dizzle's Avatar
The licensing agreement for ATF+4 requires that no matter who makes or blends the fluid, it must be manufactured with the same additive package.
The only difference is in the base oil. It has to be a (Group III); however, there are three approved suppliers. One blender may use base oil from supplier A and another may use base oil from supplier B. As I mentioned, there can be no deviance in the additive package. There is only one approved ATF+4 additive package and it is manufactured by Lubrizol. Every licensed blend has to use it. Thus, no matter what name is on the label, whether it's Valvoline, SuperTech or any other on the CQA list. If it's a licensed blend the fluid in the bottle is chemically the same.
cbrahs
04-17-2007 11:59 AM
radshooter
12-12-2004 09:08 AM
muddymess
36
04-18-2003 01:12 PM
Lon
01-23-2003 10:16 PM
Quick Reply: Transmission service around Boise, Idaho
