Transmission Question??
Old 02-17-2010, 08:59 AM
m2fsr's Avatar
I scheduled an appointment with the local Dodge Dealership to have my transmission serviced on my 06 Man Van, (48re). They offered the standard flush, which I anticipated, then said that they can also drop the pan, change the filter and get this, ADJUST THE BANDS. Now, I might be wrong, so here is the question. I thought that the 4 speed in my truck was solenoid activated and did not have bands in it at all? Am I correct in this statement.
Old 02-17-2010, 09:05 AM
glocklove's Avatar
Yes they have bands and yes they can be adjusted..
Old 02-17-2010, 10:19 AM
Matthew999's Avatar
I have an '06 3500 5.9. Over the last few days I have noticed the transmission occasionally doesn't seem to want to upshift normally. It hesitates, requiring a higher than usual engine RPM to encourage the upshift. Any thoughts or suggestions would be greatly appreciated!
Matthew
Old 02-17-2010, 03:10 PM
DBLR's Avatar
You don't need it flushed unless you burnt the fluid. Just have them drop the pan install a new filter and refill it, about 6.5 qts of ATF. Every time the trans is serviced, install a new filter they cost $20. or less an its a requirement, but you don't need the bands adjusted at every service. I've had Dodge service managers agree band adjustment is not needed at service unless its slipping.
Dauntless
15
08-30-2016 08:37 PM
turbospl311
02-04-2003 09:14 AM
CRobey4393
01-16-2003 07:54 AM
CNYRAM
12-23-2002 11:32 AM
Quick Reply: Transmission Question??
