Transmission model #
Old 12-01-2006, 06:54 PM
RODGERDODGER01's Avatar
Can anyone tell what type of auto tranny is in my truck, it's a 98 2500 QC 4x4 4 sp overdrive, thanks
Old 12-01-2006, 07:16 PM
TIMMY22's Avatar
47RE
Automatic, 4-Speed Overdrive Gear Ratios
Transmission 42RE 46RE 47RE
Order Code DGK DGT DGP
1st Gear 2.74 2.45 2.45
2nd Gear 1.54 1.45 1.45
3rd Gear 1.00 1.00 1.00
4th Gear 0.69 0.69 0.69
R Gear 2.21 2.21 2.21
Torque Converter
Diameter 273 mm
(10.75 in.) 273 mm
(10.75 in.) 310 mm
(12.2 in.)
Input Torque
Rating (ft-lb) NA NA 450
GCVW (lb) 7,800 14,000 19,000
Application V6 2WD V6 4WD, V8
V10, Diesel
Refill Capacity after a fluid change - 47RE: 6 1/2 quarts reported on the TDR Forum.
Automatic Transmission Identification
Transmission identification numbers are stamped on the driver side of the case flange just above the oil pan gasket (just below the TV lever). There will be a 9 digit part number, a space, a 4 digit build date, a spave, and a 4 digit serial number.
Subject: Re: [RAM] (RAM) Transmission ID
To: ramtruck
> It's time to change the filter and adjust the bands on my truck. Is there an
> easy way to identify my transmission? (47RE or 46RE)?
Auto Trans code breaks down like this:
4 = 4 forward speeds
6 = strength of trans. (1-9, higher number, stronger trans.)
R = Rear wheel drive
H=Hydraulic controlled, E = Electronic controlled shift
Old 12-01-2006, 07:29 PM
Thumbs up
Excellent, thanks
Old 12-01-2006, 08:58 PM
Sidewinder's Avatar
And I was only going to say it's a 47RE. Thats alot of detail Timmy! Nice post!
RedRam410
02-02-2007 10:27 AM
Big Nate
11-09-2006 08:56 PM
Hoss
03-26-2003 06:42 AM
CTD2500
03-25-2003 02:35 PM
12-02-2002 02:42 AM
Quick Reply: Transmission model #
