Transmission concerns
Old 04-03-2008, 08:48 PM
onetontrucker's Avatar
First of all, I see already that this site is gonna be addictive! It's awesome. I have a new 07 3500 with the 6.7 with an automatic. I have noticed when it's under a load it will shutter or shake for just a seconds when starting off. A friend said his done the same thing until he got a few miles on it. (he didn't say what a few was) I now have 17,000 miles and it doesn't seem to be getting any better or worse. Have you guys experienced this?
Old 04-03-2008, 09:59 PM
hamilton71801's Avatar
Maybe it's axle windup??? I had a Ranger that did that and the problem was the grease that the factory put on the yoke dried up which lead to the windup. I put some moly grease on it and fixed it. Just a thought.
Old 04-03-2008, 10:07 PM
JuzPlaneKrazy's Avatar
My 06' does it too. And most of the guys on here say there's do it too. As soon as I hook my trailer up it go's away.
Old 04-03-2008, 10:17 PM
That makes sense then. When unloaded there is slack between the yoke and driveshaft because the grease is dry or not much there. When you put a load on the driveline, you can't feel the slack because it's putting the power to the wheels...make any sense? I'm not real good at explaining things. Anyway, I'd take the driveshaft down and pack it with some moly grease and see if that didn't fix it. If not, what did it hurt to try?
Old 04-08-2008, 03:06 PM
Mine is backwards I guess, it only does it when it IS hooked to a heavy load. Right now its more annoying than anything else.
Old 06-09-2008, 10:16 AM
Mutt68's Avatar
My 06 does it both empty and loaded. It is alot more noticable with the fifthwheel hooked up. It shutters off a dead stop to maybe 15 MPH or so. I was thinking the converter was going.....any thoughts???
Matt
Old 06-09-2008, 10:48 AM
belgianmagic's Avatar
this is a GREAT reason to put a SPACER (SHIM) between the carrier and Bearing...LOWERING IT
you put weight on it and it stops...your carrier bearing is too high
pjc360
04-16-2012 10:10 AM
midwestdually
08-27-2003 09:48 PM
midwestdually
08-27-2003 08:33 PM
luie
08-20-2003 10:36 AM
Quick Reply: Transmission concerns
