transmision not shifting right
Old 12-29-2007, 05:43 PM
tonystruck's Avatar
Question transmision not shifting right
I had problems with tranny shifting into overdrive - i followedinstructions on here and cleaned the tps- also check voltage- it was fine- 5.0v @ reference1.5v @ an idle, 4.0 volts @ full throtle it shifts better into overdrive now but its hunting for gears 1-3???????
Old 01-10-2008, 12:00 PM
jayjay's Avatar
hopefully you got it fixed, but if not, try replacing the brushes in your alternator. This was happening on my '02 and thats what is ended up doing.Apparently there is static ''noise'' that originates here and it affects shifting.
Old 01-10-2008, 05:16 PM
Buckshotram's Avatar
What year is your truck??? I believe the tps only controls the 3-4shift and tc lockup.
snowwjob1
17
06-08-2009 06:55 PM
Brendan
10-17-2007 11:12 AM
tonystruck
10-16-2007 11:12 AM
tonystruck
10-15-2007 09:47 PM
98 Ram 24V
12-24-2005 10:19 AM
Quick Reply: transmision not shifting right
