Transgo shift kit pressurer readings?
Old 09-02-2009, 03:42 PM
flattracker's Avatar
Anyone have line pressure readings on a 48re after transgo shiftkit installation? Thanks in advance.
Old 09-03-2009, 06:00 PM
No one checks their pressures after installing a shift kit????
Old 09-03-2009, 07:18 PM
JFlory's Avatar
I'll give it a whirl, but I have never just installed a transgo kit without doing other mods to the VB that aren't in the instructions.
Here is a close to accurate 48re:
Idle, in gear - 80-90psi
Cruising, TC locked - 130-160psi (depending on how much throttle is being applied)
WOT - 180-200psi
Pressure should come up smoothly, but quickly with throttle. At around 120-130psi, shifts to 2nd gear. Same for 3rd. If and when the TC locks in 3rd you'll see 150ish. OD is around 120-130, then you get TC lock up in OD, and see 130-160psi.
Not exact by any means, but it may be helpfull to ya. These numbers may be 10-20psi higher than a normal VB with just a shift kit. Also these are on built tranny's, whitch tend to have better pressure, too.
Old 09-03-2009, 10:45 PM
ShutupAndHoldOn's Avatar
WOT - 180-200psi
Thanks for the great info, but of course it begs the question...What are those other mods that aren't in the instructions??????
Old 09-07-2009, 08:02 PM
Thanks JFLORY , exactly what I needed
Old 09-08-2009, 05:08 AM
1985cucv's Avatar
extra stuff like servos and billet levers and stuff like that and an aftermarket tc
Old 09-08-2009, 11:14 AM
BigDogJeepin's Avatar
Extra stuff to include:
Billet parts from http://www.transmissioncenter.net/dodge.htm
#3SC - Intermediate Servo Cover or #3S2 if you don't mind the extra cost
#4BA - 2nd gear band anchor
#4BS - Band Strut
A billet second gear band apply lever like #4LG. Not sure if the levers they list are the correct ones for your application.
Old 09-08-2009, 09:10 PM
1985cucv's Avatar
there is one deeper down th epage i believe for the 48re the lever has to be put in with the trans out! everything else is a cake walk
Old 09-09-2009, 03:21 AM
Yes, the second gear apply band lever can only be replaced by removing the tranny.
shrmpboatcptn
11-16-2010 06:46 AM
USCGtraveler
19
08-10-2004 08:22 AM
firepiper
04-16-2004 11:02 PM
dansdodgediesel
11-28-2003 09:17 AM
RickCJ
01-15-2003 06:42 PM
Quick Reply: Transgo shift kit pressurer readings?
