transfur case lube ?
Old 04-19-2007, 08:47 PM
oldblues's Avatar
Question transfur case lube ?
hi
checked my transfur case lube today and it was not pretty . 98 12 v 4x4 auto
dark and looked /smelled like trans fluid ?
what lube belongs in there ?
what is everyone using ?
what size is the drain plug thread so i can get a magnetic one / took a 10 mm allen to remove /install it .
thank you !
Old 04-19-2007, 10:54 PM
Mslaughter's Avatar
I used Dex III, took about 2.5qts.
Old 04-19-2007, 11:40 PM
leprechaun's Avatar
My owners manual says to use dexron III.
Old 04-20-2007, 12:21 AM
fbx22's Avatar
I sure hope it smells like trans fluid
Old 04-22-2007, 09:35 AM
fschiola's Avatar
The owners manual on my 1997 states that for a NV 241, it should be 6.5 pints of ATF+2 or Dexron III. The service interval is every 30,000 miles.
Old 04-22-2007, 10:27 AM
Box5's Avatar
I used ATF +4. It took 3 1/2 quarts for me (manual said 4, but it wouldn't fill anymore even with the t-case level. I've got the 241 DHD.
mknittle
03-11-2015 10:47 AM
wyododge
08-18-2011 07:48 AM
dssimecek
03-10-2008 04:58 PM
D.S.
04-15-2006 05:31 PM
bigred496
06-12-2004 04:59 AM
Quick Reply: transfur case lube ?
