Transfer case gearing?
Old 03-26-2006, 10:21 AM
kawi600's Avatar
Is it possible to alter the gear ratio inside a transfer case (rather than both ring and pinion sets) if you wanted better cruising RPM?
Old 03-26-2006, 03:22 PM
Tate's Avatar
2wd an 4hi are a direct drive through the t-case. You can get aftermarket gear sets for deeper low ranges, but that won't help cruising rpm any.
Old 03-26-2006, 04:27 PM
TRCM's Avatar
only way to do that, is either swap axle gears, or put a overdrive unit between the trans & tcase, or on the tcase output if you only want to use it in 2wd
wyododge
08-18-2011 07:48 AM
csramsey640
07-06-2006 04:44 PM
8mpg
05-22-2006 01:35 PM
malibu
02-18-2003 07:21 AM
Quick Reply: Transfer case gearing?
