Transfer Case Fluid Level
I have the manually operated (NV-271?) transfer case. I changed out the fluid and put in 2 qts which is what the Amsoil site says is the capacity. I have also read where you should fill the transfer case to the top of the fill plug. 2 quarts did not do this nor was the transfer case filled to the fill plug when I checked it from the factory.
What is the correct amount/level? If it is to the top of the fill plug any idea how many qts this is?
Thanks,
Tom
Thanks,
Tom
Commatoze
16
Sep 23, 2003 11:15 PM
