Transfer Case Fluid (ATF +4 9602 or Gear Oil)
Old 10-17-2005, 11:02 AM
vrj
vrj's Avatar
I understand that depending on the year of your truck and type of transfer case, the operating fluid would be different.
Some use the ATF +4 9602 and others use good quality gear oil (i.e. 85w/140 valvoline /lucas/amsoil ect...).
As listed below, I have a 2001 2500 3/4 ton. I 'm not sure what transfer case is on my truck. Is the model number clearly displayed on the transfer case? What fluid goes in what transfer case? My owners manual is somewhat unclear.
Thanks!
Old 10-17-2005, 04:49 PM
jd4030's Avatar
I have a 2002 & it calls for ATF+4 in both the transmission (auto) & transfer case. ATF+4 is backwards compatible, I believe the requirement started in 2002. Does anyone know the difference in ATF+3 & +4? I use +3, not paying what the dealer wants for +4.
Old 10-17-2005, 05:48 PM
slim51015's Avatar
Recommended lubricant for the NV231 and NV241
transfer case is Mopart ATF +4, (MS 9602) Automatic
Transmission Fluid.
Old 10-18-2005, 05:48 PM
ridofpwrstroke's Avatar
you should use atf for the t-case on the auto's, but is it the same with the manuals.
Old 10-19-2005, 09:39 AM
Moose10's Avatar
I put Amsoil ATF in my t-case almost a year ago....seems to shift a bit more smooth.
p.s. I'm not an Amsoil dealer or pusher, just found a good sale price on it one day
Old 10-19-2005, 12:02 PM
VADSLRAM's Avatar
I just picked up a '90 wrangler and it calls for ATF. I looked back through the service manual and all the listed cases site ATF as the fill.
Old 10-20-2005, 05:47 PM
Marine's Avatar
I also filled mine with Amsoil.
sallyman1
16
08-15-2009 04:38 PM
moparlvr
05-13-2008 10:27 PM
Mslaughter
08-24-2006 06:44 PM
perk
02-29-2004 12:20 PM
Quick Reply: Transfer Case Fluid (ATF +4 9602 or Gear Oil)
