Transfer Case Capacity
Old 09-16-2005, 07:55 PM
Commatoze's Avatar
Question Transfer Case Capacity
Hafta drain the transfer case and replace the fluid. It's wayyy overdue! Does anyone know how much the NV241LD transfer case holds?
Old 09-16-2005, 08:00 PM
Marine's Avatar
I replaced mine with Amsoil ATF. I don't recall how much but I believe I bought 4 qts and I think I had some left. Drain it out in a measured pitcher, that will tell you.
Old 09-17-2005, 12:48 PM
phox_mulder's Avatar
Just make sure you get an identical replacement for when the wife sees you filling her big measuring picture with stanky ATF.
phox
Old 09-17-2005, 07:25 PM
jfpointer's Avatar
FSM says 4.61 pints of ATF+4, Chrysler spec 9602, and to fill to the bottom of the fill hole. So three quarts should be more than enough. Oh, torque spec on drain and fill plugs is 30-40 ft-lbs., which is a pretty loose torque spec. "Tight enough that it doesn't leak" probably would have worked...
Old 10-02-2005, 09:26 AM
lumpy_63's Avatar
Just changed mine yesterday, it took about 2.75 quarts of ATF+4 to fill it to the bottom of the fill plug hole.
Old 07-19-2019, 08:35 PM
MDS
MDS's Avatar
Question NV273D Oil Capacity
Just changed my transfer case oil in a Ram 2500 with NPG/NV 273D and it took 2.75 quarts. Strange the spec is 2 quarts...any thoughts? I've noticed a few other people have experienced this.
SDHNTR
05-30-2011 05:48 PM
rmalone
08-21-2008 07:35 PM
ib516
04-21-2007 08:08 PM
snowrodeo
09-18-2004 10:16 AM
Quick Reply: Transfer Case Capacity
