Transducer in Tranny...
I am wondering if anyone else has issues with the the transducer going out constantly in their truck? I am on I think my third one. Last time I replaced the solenoid and transducer thinking maybe it was one casuing the other problem. Anyone have any ideas as to what causes one to fail so much? I get maybe 3-5k miles out of one.
Billet Suncoast is the problem. Quite likely its the gov solenoid causing the issues if its shifting thats the problem. The fix is the aftermarket solenoid.
If its actually the transducer quitting then you have another problem somewhere.
Built transmissions are hard on the gov solenoids because of the pressures they. Could possibly be the reason for the transducer going out also though that doesn't seem to be as big a problem.
From the perspective of the OE pieces the built trans is the problem. From the perspective od what a built trans gives you the OE garbage is the problem.
Do you have an upgraded solenoid or the stock one?
KillerBee
12-27-2007 10:45 PM
