Trans temp
Old 05-03-2006, 08:51 PM
scottsjeeprolet's Avatar
Trans temp
What are is the danger zone on a trans temp. I installed a guage a while ago and need to know what temps to watch out for.
thanks
scotte
Old 05-03-2006, 08:54 PM
phox_mulder's Avatar
Depends on where you installed the temp probe.
I've seen 280 on mine, and can tell you unoquivocely(sp?) that is bad mojo.
There's a chart that's been posted numerous times with a bunch of temps, and tranny fluid life expectancy at that temp.
Maybe a search for tranny temp will produce it.
Found it, one of them at least.
phox
Old 05-04-2006, 02:15 PM
Cageman's Avatar
My tranny guy said 240 - 260 turn it off
Old 05-04-2006, 02:34 PM
ratsun's Avatar
__________________________________________________ _______
I wouldnt do that!!
Pull over and idle in nuteral (or park if VB mods for flow were done) so it cools with fluid circulation, that will cool it down faster.
If your seeing 240-60 pan temps the oil coming out of the converter is likely well over 300 so that oil already needs changing
Old 05-04-2006, 02:37 PM
zukgod1's Avatar
I wouldnt do that!!
I'll second that..
Old 05-05-2006, 12:39 PM
Cageman's Avatar
I wouldnt do that!!
That is what I ment to say
1985cucv
02-18-2010 02:03 PM
mar67655
03-21-2009 05:35 AM
Richpwb
08-15-2008 08:01 PM
djgaston
10-30-2005 03:18 PM
live wire
07-21-2003 07:26 AM
Quick Reply: Trans temp
