trans problems
Old May 17, 2008 | 03:25 PM
Rpainter's Avatar
trans problems
I just installed my trans I had Tim install new clutches and steels in the front and rear drums, I installed new clutches in the overdrive unit. just got everything installed and I have reverse but no forward gears and when I try to put it into park it grinds geare. I am hoping it is the shift linkage cause tim really knows his trans and the overdrive unit was within specs when I put ti back together. any ideas the get this truck to go forward?? thanks Robert
Old May 17, 2008 | 06:39 PM
J BODY's Avatar
Park pawl is on the output shaft. Guess you have to ask yourself why is the output shaft turning when I'm sitting still trying to put the trans in park? I was thinking Tcase not in gear properly.....but you stating you have reverse blows that theory out of the water.
Old May 17, 2008 | 06:43 PM
Rpainter's Avatar
i think I have if figured out I think the shift linkage is out of adjustment. If I move the shift lever on the side of th etrans it shifts fine but If I use the column lever if seems to get stuck between gears. it has yet to grind the gears again when I go into park??
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
pancho05
Aug 18, 2003 12:20 PM
Dodgezilla
May 18, 2003 06:00 AM
