Trans Oil Pan alternative to the $$ aluminum.
Old 04-10-2009, 09:42 AM
Walt L's Avatar
Hi folks,
Just wanted to through this out there for the guys in need of a new oil pan. I picked up this 12 tube cooled trans pan on E bay and am pretty happy with it. I primarily wanted a pan I could silver solder a 1/4"NPT female fitting on the side for my mechanical temp gauge and this galvanized pan was perfect for the weld job. It holds 3 extra quarts so my long temp probe sits well below the trans components. The only ***** is the pan was a little warped so you must use the hard plastic reusable type gasket, not the standard type that comes with the pan.
http://cgi.ebay.com/ebaymotors/A518-...spagenameZWD1V
Old 04-10-2009, 12:29 PM
HotRodTodd's Avatar
Looks decent.
Does it come with the filter spacer?
We use the B&M cast aluminum pans at our shop, about $40 more than that one.
But any pan that will add extra fluid and help cool, should be a plus.
Old 04-10-2009, 11:42 PM
Walt L's Avatar
I think the filter rests on the tubes. The tubes are much thicker than the pan metal and appear to be brazed solidly in place. Aluminum is nice but I personaly like my silver solder job of mateing the brass gauge probe fitting directly on to the pan. It was something I could do myself, not so with aluminum.
Old 04-11-2009, 02:03 AM
HotRodTodd's Avatar
The aluminum pans already come with a 1/4'' hole for the probe.
Even if they didn't, they are 3/8'' thick in several places and could be drilled and tapped very easily.
Old 04-12-2009, 10:56 AM
justme-'s Avatar
Um, Walt... what are you going to do when the probe goes bad if it's soldered directly into the pan?
Old 04-12-2009, 07:00 PM
Ronco95's Avatar
In my opinion, monitoring pan fluid temps are not as good as fluid temps from the outut to the first cooler.
More fluid is a better thing though.
Ronnie
mstep3
30
04-24-2011 02:02 AM
mar67655
03-14-2009 07:22 PM
davelinde
01-11-2008 07:50 PM
tex23455
07-25-2007 02:31 AM
bostongsx
09-25-2006 11:25 PM
Quick Reply: Trans Oil Pan alternative to the $$ aluminum.
