Trans Flush almost requires a loan
well not quite ....... but I got a dealer quote for a transmission fluid flush, filter change, and band adjustment $249.95 WOW Im sure if I did the fluid flush and filter change myself Id only spend around $100 but Im not about to go tinkering with the bands. Ive read how to do it several times and I just am not confident enough that I wont mess it up. The truck doesnt like to shift into OD unless I play with the throttle. Hopefully its just needs a new filter or adjustment. The fluid levels look ok.
Doesn't sound like too bad a price, they'll spend around an hour and a half on it. I think that's the way to do it- I don't think there's much point in flushing the trans without doing the rest of the service on it. You can service it without doing the flush but if the fluid's discolored you may as well change it all.
well since it doesnt like shifting to OD I may as well have it all done and pray that it will help it shift into OD smoothly again. Because if it doesnt cure the issue then $249.95 will begin to look like chump change
Nice response.
Anyway, I can see an instance where a guy would pay to have his trans serviced, band adjusted and all. The fluid and filter alone (if bought from the dealer) would have run you over $100, not to mention the MESS and hassle. I wouldn't sweat the money, like you said the real big bill is when you have to swap it out for a built one......
The trans flush fill, filter and band adjustment wasn't something I wanted to tackel on a busy weekend so I called the dealer and was quoted $150. I jumped on that. If you have 2 dealers in town try the other for a better price. This was done less than 2 weeks ago so prices are current, at least here in CO.
Good luck.
Good luck.
Good luck.
Good luck.
I don't know if thats the typical "Alaskan markup" or not, but I got that job done at a alocal tranny shop that does really good work (flush, service, adjust bands, and check line pressure) for $175, and I'm in Canada.
I'd say shop around.
I dunno, a thirty year tranny guy told me to NEVER flush a 47re. He said that regular changes and filter replacement is all you need. If you do a search you can pull up a thread that tells you how to remove one of the tranny lines and change ALL the fluid yourself for a fraction of the cost.
I do what Dr. Evil said, I unhook a line and allow the fluid to run out. I believe it is the passenger side line. Just make sure if you do this to make sure that the fluid is topped off, only allow it to run for a couple of seconds before shutting down and refilling. You don't want to run anything dry. I drop the pan, change the filter, then unhook the line and get all the old fluid out. You'll be able to see the color change.
On a positive side note though, while installing a new hot line after the trans was serviced, they must have bent the pan while draining it because there is a brand new deeper pan on the 47re now, no charge from the dealer.
Good luck and keep searching.
You are correct, and I should have been a little more clear - I was talking about a POWER flush...
After getting what was likely over a gallon to a gallon and a half(US) in a a tiny drain pan I *assumed* I got half of what was in the TC.
I dropped the pan to change the filter and it easily went to 3 gals (total) in the big drain pan. Still red-brown but wasn't nice and clear like the new AFT.
I bought a case of ATF-4 and added 1 more to boot. 13 US Qts in a 47RE. I would say I got almost all out without having a drain plug on the TC.
YMMV...
Someone mentioned his 2001 wouldn't drain like crazy when he pulled his hot line. I wonder if the check valve is at the tranny on the '01's -vs- at the cooler like my '97?
