trans fluid cap.
Old 11-29-2006, 04:12 PM
somis13's Avatar
trans fluid capacity
do the autos in are diesels have bigger transmission pans then the gasers? and what is the capacity of mine?
Old 11-29-2006, 07:10 PM
TIMMY22's Avatar
fill in you signature so we know what year.
-dodge ram.org
Automatic, 4-Speed Overdrive Gear Ratios
Transmission 42RE 46RE 47RE
Order Code DGK DGT DGP
1st Gear 2.74 2.45 2.45
2nd Gear 1.54 1.45 1.45
3rd Gear 1.00 1.00 1.00
4th Gear 0.69 0.69 0.69
R Gear 2.21 2.21 2.21
Torque Converter
Diameter 273 mm
(10.75 in.) 273 mm
(10.75 in.) 310 mm
(12.2 in.)
Input Torque
Rating (ft-lb) NA NA 450
GCVW (lb) 7,800 14,000 19,000
Application V6 2WD V6 4WD, V8
V10, Diesel
Refill Capacity after a fluid change - 47RE: 6 1/2 quarts reported on the TDR Forum.
Automatic Transmission Identification
Transmission identification numbers are stamped on the driver side of the case flange just above the oil pan gasket (just below the TV lever). There will be a 9 digit part number, a space, a 4 digit build date, a spave, and a 4 digit serial number.
Subject: Re: [RAM] (RAM) Transmission ID
To: ramtruck
> It's time to change the filter and adjust the bands on my truck. Is there an
> easy way to identify my transmission? (47RE or 46RE)?
Auto Trans code breaks down like this:
4 = 4 forward speeds
6 = strength of trans. (1-9, higher number, stronger trans.)
R = Rear wheel drive
H=Hydraulic controlled, E = Electronic controlled shift
-dodge ram.org
you will not need the whole ammount if you are just dropping the pan. the rest will stay in the torque converter. remember level ground, engine running, transmission in neutral, slowly pour in. check in N engine running warm.
Old 11-29-2006, 07:52 PM
somis13's Avatar
I filled it out but it doesn't come up when I post. what am I doing wrong in that department. the truck is a 1998 2500 4x4 long bed quad cab 12 valve automatic. the real question is. Did I waste my money on the B&M deep pan or does it really hold more fluid? It looks the same
Old 11-30-2006, 10:21 AM
infidel's Avatar
You are most likely filling in your profile but not your signature.
Old 11-30-2006, 11:18 PM
88bird's Avatar
i know when i got my tranny from Goerend i ordered it with a MagHytech single deep pan..... it is deeper than a stock pan.... did you set the two pans side by side and look at them? does the B&M have cooling fins on it? they help some..... as for fluid capacity honestly i can't rember the refill after a filter change but as stated above 6.5qts sounds a little high... i want to say 5or so...... but when i installed my new tranny it took 19.5qts before it was full on the stick..... but that was bone dry...... have checked it numerious times and it's still dead on......
VFDFireman
01-05-2008 06:47 PM
sterling
10-19-2007 05:32 PM
icrider
09-27-2006 03:10 PM
gbcop
06-15-2006 01:20 PM
ajpulley
01-16-2006 04:21 PM
Quick Reply: trans fluid cap.
